- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Well thats the plan haha gotta sell my truck first though.
| Sponsored Links |
The bottom line is, if you haven't towed with a 7.3 you are in for a real treat. See how well you think the 4.6 performs after towing the same load with the 7.3!! |
My dad has a 7.3 with 4.10s. We both love it. The problem is is that it is 2wd. Now im not doggin on 2wds, but if its gonna see any kind of off road like a field or anything might as well have the 4x4 option. Its just too convenient in my opinion not to have. There has been a few times he could have used it and had to get out my 4x4 4.6 in low to pull his *** out. Back on topic haha The 4.6 does great with a utility trailer and a mower and lawn care equipment on it, does ok with a few 4 wheelers on the trailer, but with a car trailer and a car on it, it grunts. I pulled a trailer with my 34 ford rat rod from here in cincinnati to marietta ohio (about 3.5-4 hours away) on rt 32. There is a hill between jackson and 73 that is long and semi steep. I had to use 3rd gear to the floor to get it up the hill at 50 mph. Did the same hill same trailer same truck on the trailer with my dads 7.3 and i did it at 65 (where i had the cruse set) and didnt even shift out of OD--- I know that wasnt good for it i just wanted to see if it would do it--- I am doing more and more buying and selling of vehicles (just bought 2 '66 International Scouts from WV) had to use dads truck to get em home. So I guess what I am saying is that I think I can justify a diesel (not to mention i just plain out want one.) I just thought a PSD in my truck with all the 3/4 ton running gear and susp. would be cool. I guess i might as well buy a 2 or 350 and be done with it. Soo, who needs a beautiful '98 F-150? |
PSD in F-150
It "might" work, but is probably going to be more time, trouble and cost than it is worth. My first concern is the heavier weight (as already mentioned by someone else). Diesel engines outweigh gassers by a significant margin, and your front suspension might not be up to the job. Second, would it even fit? Look at the hood on the F-150 and then on the SuperDuty. There is a big difference in the size and shape of it. Doesn't the F-150 hood slope downward a bit much? Look at the front grille also -- will the larger radiator, alternator, turbo hardware and dual batteries fit up in there? Maybe; maybe not! ![]() Finally, what about the suspension, chassis, fuel electrical systems? There are bound to be differences there! My off-the-cuff recommendation would be to just go out and find a used SuperDuty that already has a diesel engine from the get-go. ![]() |
Still need to sell my truck though.... |
The only real reason to do this would be if you just LOVE the body style of the 150, but need/want the PSD and heavy duty drive train... which you would need if you have the motor, the half ton trans (if it would even adapt) and following axles, etc wouldn't hold up for any more than the first time you put yer foot into it! SO....
If you really want that body style, find a wreaked/rolled 250 or 350 super duty, leave the motor/drivetrain/suspention/axles as they are on the SD frame, and just swap the sheet metal body over, then yer just gonna have to make the body mounts and such... leaving the frame/drivetrain in mostly factory relationships... this would be a time consumeing project, and not one you're gonna want to approch if this is your current daily driver, and you really want a project that will take months... Otherwise, easy way out, as you've said, sell your current truck, find a good used superduty in the cab/bed/x4 combo you want, and be done with it... $15K or less and you'd have a nice ext cab 4x4 PSD with around 150K miles... hook up yer trailer and set the cruise... away you go... Good luck any way you go... |
| Sponsored Links |
