I have a 2000 F350 7.3 4x4 . Only mod is a 4" lift and tires. The truck started acting like it had no power. Taking off from stop lights and such, then the next time you fired it up it would run like a scalded dog. Then it started having trouble with cold starts. Now it wont start at all.
I put a code reader on it and cannot get any codes cause the reader says turn on the ignition, so I do and It dont see any ignition signal.No fuses blown, dash lights instruments everything works ,but it wont start. The batts are full charge and only two weeks old.
I tested the reader on my 02 truck and it works fine.
I think the brain is dead.
ANY THOUGHTS? Thanks in advance.
