Max Turbo Boost psi for stock '01 7.3L? - Ford Powerstroke Diesel Forum
post #1 of 77 Old 11-26-2008, 09:53 AM Thread Starter
Just wanted to know what kind of boost a stock turbo out of a '01 should be getting. Mine does not make much! I have a edge evolution that keeps records and the highest recorded psi was 19. That is standing on it to while pulling my boat. Is this normal or low?
Thanks
2001 F-250 7.3L 4x4, 4" procomp lift, 35"x13.5 Mickey Thompson MTZ on 18"Moto Metal 955s, DP-Tuner F-5, Beans Stage 1 Injectors, Snow Performance Level 3 Max MPG water/meth, custom built tranny, DIY Napa Intake, 4" MBRP Turbo Back to 6" Mitter Cuts.
7.3LStroke is offline
post #2 of 77 Old 11-26-2008, 10:05 AM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 139 Post(s)
i've heard from guys on the org that the stock 7.3 turbo will have problems anything over 30 psi, i 'm not 100% positive on this, but i know for a fact that on mine i can hit 38 psi on my street setting and only driving 3/4 throttle
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is offline
post #3 of 77 Old 11-26-2008, 10:10 AM
Lifetime Premium Member
jbeasts10's Avatar
I can hit 34 to 36 on stock turbo,about 3/4 throttle also.I recently changed my tunes around a little to back the boost down ..still 26 to 28 all day.With NO programmer 22lbs .Maybe your not getting a good reading.
2001 F250.Custom Tuned,Ball-Buster Turbo,5"Exhaust
ITP Reg.Return,TD Billet Converter,Built Tranny,Snow Meth/Water Stage 2..plus a few more things!!She will Hunt
jbeasts10 is offline
post #4 of 77 Old 11-26-2008, 10:13 AM
Hate stupid people
Quoted: 139 Post(s)
like you said, it seems like something isn't being read right
EFI Live tuned 6.7
post #5 of 77 Old 11-26-2008, 12:06 PM
Powerstroke Junkie
NCHornet's Avatar
22 lbs on a stock truck NO WAY!!!! Where are you drawing your readings from?
A stock truck should put out 15-17lbs max. With a chip or tuner it will vary greatly as there are many variables. The stock turbo won't last long when pushed past 25lbs on a reg basis.
Remove the Supercraps tune and see what you can pull. If you can hit 15-17lbs all is good. If you can't start checking for leaks!!
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 77 Old 11-26-2008, 12:10 PM
cchase's Avatar
Yeah these numbers people get are way off! a stock turbo really isnt going over 30 on stock sticks, and even then it isnt lasting long at all
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #7 of 77 Old 11-26-2008, 12:12 PM
I am that hot
superxcrewfx4's Avatar
Mine has read up to 30 and its hooked up to the map line, at or a little after 30 is when the check engine light comes on. I have mine hooked up the way it is susposed to be...
1999.5 Ford F-250 Powerstroke
7.3 Powerstroke Diesel
4" Turbo Back MBRP with 6" Tip Straight Piped!
DIY Intake
Isspro Gauges
Diesel Site Coolant Filter
TW 6 Position Chip
2.5 Inch Leveling Kit
305/75/16 Mickey Thompson MTZ's
239k and COUNTING!!!
superxcrewfx4 is offline
post #8 of 77 Old 11-26-2008, 12:14 PM
Snowman66's Avatar
most I'v seen is 28psi @ WOT going up hill DP tuner 140, also hit 1300 deg EGT.
2000 Excusion , 125,000 mi
Stage 2 Pro Dry
4in FBD exhaust W/ Muff
Dp tunes 40 tow, 80 econ, 120,and 140
Amsoil engine, W/Amsoil bypass filter, rearend
HID
Drill some treehuggers on the way to some oil
Global Warming, is a state sponsored religion, seperation of church and state
Confuse a liberal,
present reality
Gun control is using both hands
U.N.
Snowman66 is offline
post #9 of 77 Old 11-26-2008, 07:02 PM
kkbodyshop's Avatar
my truck hit 27psi and my boost gauge is hooked to the map line with 8 foot of clear hose to the boost gauge
94.5 f350 dually
216k miles
straight piped
intake
fuel shim
ts chip
kkbodyshop is offline
post #10 of 77 Old 11-26-2008, 07:08 PM
Cj Ford's Avatar
I hit 28-30 on my extreme tune from Tony that the highest it will go and I will run right around 1200 on the egts
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
