Need help deciding between Issopro guages or Quadzilla commander?
I need some opinions on guages. I am getting guages from Nathan at farmboy diesel. I am having a hard time choosing between Issopro needle guages or quadzilla commander digital guages. I like the look of the Issopro but i also like all the things you can do with the quadzilla. I just don't know where I am going to mount the quadzilla. Anyone have any mounting ideas?
Not a fan of the Isspro gauges. I've not used them but know of a few that have had problems with them. I use Auto Meter's and have the TS-MPD Monitor with Heads Up Display. The TS gives me the ability to recall high readings after a pull. I got mine from Larry at DPP.
I have isspro's, and I like them.
Sure, I don't do any pulling like mech though. |
I have a commander and it has been awsome. Comes with four guages and you can add more. You can monitor 7 things at once. It also does data logging, so after what ever you do, you can go back and look at it or store it to the computer. Very Nice I think. I also got mine from Larry and Pat at DPP.
thanks for the info keep the opinions coming.
Thanks |
I was thinking it was Rodslinger who did a comparison of real mechanical gauges vs. the digital ones...he found that the real analog/mechanical gauge was quite a bit more accurate than the digital, especially on EGTs. However the added benefit of the "toys and gadgets" w/ the digital stuff makes them nice too..I'd just be 100% sure that what you are buying is guaranteed to be accurate! Check w/ Rodslinger..I'm almost positive that it was him that did the comparison.
I have the commander too and love it. No pillar trash crowding up my cab. Easy to read - all in one eyeshot rather than having to scan 4 different pillar guages. Mounts on the left hand corner of the dash under the Pillar with a little sticky pad...wiating for a pillar mount to come out but I actually like it where it is.
hey rodsligner do you have any input on this topic?
got the commander and love it, easy to navigate and read, check out my garage to seee where i mounted it
oh and it can control lots of chips
I've had my Commander installed for about a month now. The pillar mount should be available shortly, and that's the only thing I'd change about it. I have EGT, Boost, Tranny and Coolant temp displayed and it's great. I was looking at an Issopro gauge package that costs about as much as the Commander (which I got from Discount Power Parts) and given the capabilities of the Commander the decision was rather easy...
Matty |
