Old 11-09-2008, 05:48 PM
CoalRollinRoosterCruiser CoalRollinRoosterCruiser is online now
Mighty Mouse
Send a message via AIM to CoalRollinRoosterCruiser
Shocks
Ok, i think its time to order new shocks. My truck has seem to of started to ride really rough/hard/bouncy over bumps(in a bad way), mainly within the last week or two.
So i think my Pro-comp shocks are at the end of there life.
So my question is,
I'm either going to go with Bilstein 5100's or Icon's Signature Series.
How much better our the Icon's?
In otherwords are the worth the extra $30 a piece?
I dont mind paying the extra if there worth it, but if not, i'd rather save the money.
Old 11-09-2008, 05:52 PM
huhner5 huhner5 is offline
I have no input for you but i interested in the topic so here is a bump
Old 11-09-2008, 06:01 PM
TANK'S 250 TANK'S 250 is offline
They are pretty close to the same,....Icon's coating is a little better,....I prefer Icon's....worth every penny
Old 11-09-2008, 06:03 PM
DCSpecial DCSpecial is offline
Supporting Vendor
Difference between the two:
Icons have a clear powder coated finish to protect the shock body.
Bilstein 5100s are CAD plated.
Icons use a nitro steel shaft which is harder than chrome and lasts longer under salt spray tests.
Bilstein uses chrome.
Both issues important in areas that see road salt in the winters.
But the salt can eat the clear on the Icons as well so I recommend spraying down either shock with wd-40 or something similar to prevent any corrosion in the winter months in areas with road salt.
Valving and ride quality are very similar assuming you'd run the 5100s valved specifically for the Super Duty.
Hope this helps.
Old 11-09-2008, 06:09 PM
Mighty Mouse
Hope this helps.
That helps a whole lot.
I was actually planning on more then likely ordering from you guys, whichever one's i go with.
Do the 5100's come valved for the SuperDuty if i order them from you guys, or is that something extra i have to get done.
Are the Icon's already valved for the Super Duty's?
Old 11-09-2008, 06:15 PM
Supporting Vendor
Yep, the 5100s for your 4" lift are valved for the Super Duty.
If you had an 8" lift, then the answer would be no.
All of the Icon shocks are valved specifically for the Super Duty trucks.
Old 11-09-2008, 06:18 PM
jamstoyz jamstoyz is online now
subscribed cause i think i need a new set too. do they sell just regular shocks for non lifted trucks?
Old 11-09-2008, 06:20 PM
Lonno Lonno is offline
Huntin Beers in da barrel
I went with Bilstein 5150's dual set up and am very happy with them. I went with softer valving seeing as how I went with duals.
Mighty Mouse
Pmed you
Old 11-09-2008, 06:28 PM
Supporting Vendor
Yep, Bilstein sells stock height application shocks.
Is this for your 2wd?
