HPOP OIL CHANGE - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-03-2008, 04:48 PM Thread Starter
HPOP OIL CHANGE
i decided suck out the oil out of my hpop with my friends oil changer. i got about a quart out than filled it with new oil than ran it for 5 min and than checked it again it was still dirty so i flushed it again and now its clean. does anyone do this. it seems to run a little stronger now with the fresh oil. but i did notice that when i filled it it must have drained into the pan cause now my dipstick is reading a little overfilled prob 1/2 qt.
2001 F-250 4x4
Marty's Fuel
Swamp's 250/200's
Swamp's Tunes
PDR Super GTP Turbo
BTS
PMR'S
Soon to come - SRP 1.1
njjeep is offline
post #2 of 12 Old 11-03-2008, 04:51 PM
Other vehicle is an F250
Hank's Avatar
It does drain into the pan. There are as many on here that think it does good as doesn't. I have run one quart or so thru the plug hole just to get a little more old oil out. Check out powerstrokehelp on youtube for a complete procedure of how to get all the old oil out. Seems like a lot of trouble.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #3 of 12 Old 11-03-2008, 05:08 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
it will all eventually get changed out. It may not get changed at the same time that you drain your pan, but since when would you go through the trouble of pushing ALL the oil out of the block when you do you other oil changes? It will eventually get cycled through and changed at some point or another. I do not see a big thing in changing the resivior oil, cause you are not getting all the oil out of the block and lines, so why worry about that little bit? Did i just repeat myself? sorry....
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 12 Old 11-03-2008, 05:58 PM
lukecline
Guest
Posts: n/a
Quoted: Post(s)
holy cow lol.
of course it ends up in your oil pan! once pressurized by the hpop it either exits to the pan through the injectors or through the injector pressure regulator IPR. The only time ive ever added oil to teh resevor was on a new engine to help it fire quicker.
post #5 of 12 Old 11-03-2008, 06:11 PM
JohnQBuilders's Avatar
7.3 Injector Tune Up
Yes, I do every 15,000 to 20,000 miles I change the crankcase oil. I use Ams Oil with by-pass filter. The first time I did what Bill on,
YouTube - 7.3L LONGEVITY INJECTION TUNE UP 1 OF 4
will show in this 4 part video makes a whole big difference!
My truck very quiet for a 7.3 and never misses a beat. I have the original injectors still at 104,000. In Bill's video he has over 700,000 on his original injectors, due to regular maintenance. I do not use the ProLong he uses, the Ams Oil does not recommend it.
John
JohnQBuilders is offline
post #6 of 12 Old 11-03-2008, 11:26 PM Thread Starter
Yeah i was told that the oil that is in the hpop reservoir holds a quart and the oil rails hold an additional quart each. so all together the engine should have 18 quarts of oil. I changed it because i was also told that this oil does not circulate very well through the entire oiling system it kind of gets trapped.
2001 F-250 4x4
Marty's Fuel
Swamp's 250/200's
Swamp's Tunes
PDR Super GTP Turbo
BTS
PMR'S
njjeep is offline
post #7 of 12 Old 11-04-2008, 05:14 AM
Amount of Oil
Your would actually change about 15 for crankcase about two in the high pressure system. I could not quite get all of the oil out my self, but I used the method that Bill on the Powerstrokehelp.com shows. Works just great and the best thing is, you will notice like you did, how quit and smooth they operate.
The work is well worth it ....
post #8 of 12 Old 11-04-2008, 06:27 AM
AFBLUE's Avatar
there was a big thread about this about 3-6 months ago, and for the life of me, I cant get the stupid searach function to find it. I think it was titled "top end oil"
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #9 of 12 Old 12-12-2008, 01:58 PM
metallitera's Avatar
thats why we cant find it. search only lets you search 4 letters per word or more.
-ReD
Fire Lieutenant/Paramedic, Tinkerer
1990 Jeep Wrangler YJ
metallitera is offline
post #10 of 12 Old 12-12-2008, 02:03 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Changing the oil in your HPOP is absolutely unnecessary. Every time you change your oil the majority of it gets changed.
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
