EBPV delete - Ford Powerstroke Diesel Forum
post #1 of 24 Old 02-12-2014, 07:45 PM Thread Starter
Machinist & Fabricator
h0trod's Avatar
Quoted: 47 Post(s)
Garage
EBPV delete
ive been tearing into my 01 for the past several days.
ive replaced headgaskets, installed a fresh set of heads.
replaced O-rings in the oil cooler, and new water pump.
now to break down the turbo and replace the guts with a unit I got from pure turbo with the billet compressor wheel.
ive seen videos on youtube where they cut off the EBPV.
from what I understand, that this is for cold conditions.
I am in California, so it don't get "cold"
this truck came with a BD exhaust brake so my stock EBPV does not do a damn thing.
id like to get rid of it.
have any of you done this?
cutting the cylinder off the pedestal, and welding up the inside holes?
what are your thoughts?
h0trod is online now
post #2 of 24 Old 02-12-2014, 08:18 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
their is a video on how to do this in the 7.3 tech files section.use a freeze plug for the ex housing then a bolt where the actuator comes out
i opted to just by the non ebpv pedestal and outlet, for a cleaner, leak free setup.
blue99stroker is offline
The Following User Says Thank You to blue99stroker For This Useful Post:
Rstar (03-31-2014)
post #3 of 24 Old 02-13-2014, 07:46 AM Thread Starter
h0trod's Avatar
Quoted: 47 Post(s)
Garage
I just purchased a EBPV delete pedestal.
150 bux.
my only concern was that my aluminum welding is sub par.
I didn't want to keep the barrel on for the ease of install.
this new piece will make that happen a lot easier and cleaner like you said!
post #4 of 24 Old 02-13-2014, 07:58 AM
Jerrybizzle's Avatar
Quoted: 23 Post(s)
Does the stock high idle function still work if you delete ebpv? I realize the flap won't close but does it still high idle when cold?
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #5 of 24 Old 02-13-2014, 08:24 AM
Mine still high idles with the ebpv and Aih removed and it's been below zero at night here for quote a while
crazy talk customs is offline
post #6 of 24 Old 02-13-2014, 11:51 AM Thread Starter
h0trod's Avatar
Quoted: 47 Post(s)
Garage
My pedestal and turbo came with an aftermarket exhaust brake, so the stock housing was removed and the valve itself was still in the pedestal not being used.
I havnt gotten this truck fired up yet, im hoping tomorrow.
post #7 of 24 Old 02-13-2014, 09:50 PM
Yes it does.
Greenman01 is offline
The Following User Says Thank You to Greenman01 For This Useful Post:
Jerrybizzle (02-16-2014)
post #8 of 24 Old 02-15-2014, 06:05 AM
Quoted: 258 Post(s)
ouch most vendors sell the non-ebpv pedestal and high flow outlet for 180 bucks.
and you might need to get a ebpv delete plug from riffraff so you dont throw a soft code come smog time.
i just got one from riffraff
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
post #9 of 24 Old 02-15-2014, 06:32 AM
m j
so the BD exhaust brake is a waste of money in that the factory stuff could be wired to do the exact same thing??
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #10 of 24 Old 02-15-2014, 08:40 AM Thread Starter
h0trod's Avatar
Quoted: 47 Post(s)
Garage
if I was to purchase a BD exhaust brake, I wouldn't. but if said exhaust brake came with the truck, then no moneys have been waisted...
