OBDII info question - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Rammstein1224
post #1 of 7 Old 02-12-2014, 12:38 PM Thread Starter
OBDII info question
I'm wondering if there is a stock pid in our trucks that feeds temperature data through the OBD2 port that isn't really necessary for correct operation. If so, can that sensor then be displaced with an EGT probe as a way to get EGT info through the OBD2 port? If you could do this, you could get a $5 dollar app, a $20 wireless OBD2 dongle and read EGT's, all for $25. But I suppose you'd have to get a probe to feed into the repurposed circuit, so maybe another $20. That could pan out to full gauges, code reading, some performance testing and data logging, including EGT (although that app may call the pid "ambient temperature" but its really repurposed for EGT), for $45. Any thoughts?
Can anyone think of any other way to feed EGT data through the OBDII port?
Thanks
2000 Ford Excursion 7.3, AIS intake, 4" MBRP exhaust, PHP Hydra Chip, Bilsteins (5100 in front and 4600 in back) and x code front springs to be added when I can find the time to put them in.
MAArcher is offline
post #2 of 7 Old 02-12-2014, 05:56 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
i dont think there is any stock sensors that monitor egts.
blue99stroker is offline
post #3 of 7 Old 02-12-2014, 06:47 PM
Joel's Avatar
Quoted: 10 Post(s)
I wonder how the computer would react if you told it the ambient temperature was 1200 degrees haha
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 7 Old 02-12-2014, 07:24 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
It would say why the F are you driving on Mercury.
But theres no sensors anywhere in the exhaust system let alone they would melt if you put any of them in there. Theres a reason thermocouples are so expensive
Joel likes this.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 7 Old 02-13-2014, 06:33 AM
7.3LDriver's Avatar
Quoted: 5 Post(s)
OP, do you have the app and the wireless OBD2 dongle on a iphone? how does the wireless system work for you? I was looking at doing that last night.
E99 F350 eclb drw 7.3L 4X4
220,000miles
leveling kit
35" tires
Donaldson Replacement 6637 Filter
Diamond eye 4" TB
ts6 with informant6 monitor
180/30 full force diesel injectors
d66 turbo
Riff Raff HPX and FRX
valair clutch
Zoodad Mod
Cam-locker toolbox
7.3LDriver is offline
post #6 of 7 Old 02-13-2014, 07:09 AM Thread Starter
I don't have it because I need egt and the only way to do that with an app is use Kiwi2 and the $150 egt accessories. That's why I was hoping to find a way and rout egt data through the obd2 port.
MAArcher is offline
post #7 of 7 Old 02-13-2014, 09:00 AM Thread Starter
To illustrate what I was hoping for better, imagine if you didn't need the intake air temp sensor for the engine to run correctly and you could pull it out of the intake, wire it to a $20 type k thermocouple and install it in the exhaust manifold. Then when you used a cheap $20 OBDII dongle and $10 DashCommand app, you could read your EGT's by using the app to view "intake temp" which would now really be EGT's. The result would be for $50 you'd have a full set of gauges with all the code reading and performance testing that the app offered.
Does anyone have a list of PIDs or sensors that are on a 7.3? I'm hoping there is one that we can do without and use to repurpose for EGT's.
Or if not repurpose an existing PID, are there any wiring/programming guru's on here who can figure a way to just add a PID? Or connect an EGT sensor to an unused PID, like if the vehicle in question didn't have all the factory options installed and you were taking that "blank" space to use for EGTs?
MAArcher is offline
