bad white smoke - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-12-2014, 08:18 AM Thread Starter
bad white smoke
Negative 13 this morning.on my way to work a nine mile trip my truck smoke like crazy all the way.the harder on throttle the more white smoke.could I have injector sticking? It smells like normal diesel just smokey? Runs good all numbers look good no codes
adams01 is offline
post #2 of 10 Old 02-12-2014, 08:20 AM Thread Starter
Sorry for some reason I double posted
adams01 is offline
post #3 of 10 Old 02-12-2014, 08:25 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
if its running normal then it's normal while cold...same reason as a gas motor.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 10 Old 02-12-2014, 09:23 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Except you can simulate a forest fire with the amount a diesel puts out
But OP if your getting ALOT of white smoke while driving your just pushing it too hard for as cold as it is. Either warm it up a bit with high idle and EBPV before taking off or take it real easy until it warms up(i.e no highway/interstate driving).
I like to keep it a bit under 2k rpms until it warms up to about 100 then ill drive a little more normally until its up to temp then its fine to drive whatever you normally do
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 10 Old 02-12-2014, 09:48 AM
'01SilverBullet's Avatar
Quoted: 4 Post(s)
That steam is normal when it's that cold...our T800 Kenworths both do the same thing, especially when we're on the throttle. Even the John Deere that we're using to push snow piles will do it.
2001 F250, 7.3, Automatic, 4x4, 33's, Leveled, Cobra 29 CB Radio, Single Firestick anteanna, Pioneer Head Unit, Riffraff 6637 Intake Kit, 4" turbo-back straight pipe, Dual Alternator Upper Radiator Hose, AutoMeter Boost, Pyro, Trans Temp, CM RD Flatbed with Gooseneck and Rear Hitches...and a heavy right footed driver...
Wishlist: 160cc single shots, GT38r, BTS, SRP 1.1
REAL TRUCKS DON'T NEED SPARKPLUGS!!
Lord, please take care of this drivin' fool...
'01SilverBullet is offline
post #6 of 10 Old 02-12-2014, 01:32 PM Thread Starter
Just never saw that much smoke out of it.pulling out of a stop sign the poor car behind me I could barely see their headlights. :-).
This is the coldest its been since I bought it two years ago.at lunch time itwas back to normal though.thanks for clearing this up.learning as I go with it
adams01 is offline
post #7 of 10 Old 02-12-2014, 02:00 PM
schlutzer's Avatar
Quoted: 18 Post(s)
This was my truck a few weeks ago at -30*Cish, exhaust dumps under the bed right now. It will puke that acrid smelling smoke for a while. Starts doing it around the freezing mark but gets worse the colder the temp is.
Even so, it's pretty well cleared up after 15 minutes maximum.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #8 of 10 Old 02-12-2014, 02:22 PM Thread Starter
that's what mine looked like going down the road
adams01 is offline
post #9 of 10 Old 02-12-2014, 03:06 PM
Macon's Avatar
How long were you driving it? If you can, plug it in when it's cold. Some people are proud of their trucks being able to fire right up in cold weather. That's great and all, but I don't want to cause any undue stress to my injectors by forcing it to run with honey for oil.
As for it continually smoking while driving. If you didn't drive for long...meh. If you drove for a while and it kept bellowing the white smoke, you may have a fubar'd thermostat. You can throw a piece of card board in front of the radiator to help a little until you can replace the thermostat.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #10 of 10 Old 02-12-2014, 03:16 PM Thread Starter
I had it plugged in and left it run for about 7 minutes then headed down the road it never made it to operating temp till I got to work about 10 miles away.tonight on the way home it was 20 out and it didn't smoke at all
adams01 is offline
