oil cooler assembly questions - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-11-2014, 08:55 PM Thread Starter
Machinist & Fabricator
h0trod's Avatar
Quoted: 50 Post(s)
Garage
I hope im not buggin you guys with my rookie questions that may or may not be stupid.
I got the oil cooler assembly apart and cleaned for reinstall.
what is the best way to seat these o-rings?
I was gonna put it in a small press, but I thought id better throw it out there first.
second, I noticed there are 2 pins on the barrel, do these need to be clocked in a certain position?
finally, would you use oil or grease to lube these o rings up?
thanks!
h0trod is offline
post #2 of 6 Old 02-11-2014, 09:18 PM
Greenman01 is offline
The Following User Says Thank You to Greenman01 For This Useful Post:
h0trod (02-11-2014)
post #3 of 6 Old 02-11-2014, 09:30 PM
schlutzer's Avatar
Quoted: 18 Post(s)
People need to stop linking that video. Leaving the front cover on can result in damage, I've seen it, I've fixed it. Sometimes these covers can be very very hard to separate and press back together.
To the OP, this video shows how to put the cooler back together.
As for lube, I've used oil, engine assembly grease, wheel bearing grease, and vaseline. It's surprising but vaseline is the best I don't know why but it makes it press together the easiest.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 6 Old 02-11-2014, 09:40 PM Thread Starter
h0trod's Avatar
Quoted: 50 Post(s)
Garage
https://www.youtube.com/watch?v=buBJV64vJew
I thought it was kind of insane not to replace the other gasket as well, while you are there...
h0trod is offline
post #5 of 6 Old 02-11-2014, 09:41 PM
schlutzer's Avatar
Quoted: 18 Post(s)
That too.
But yeah do what he did in the video to line up the two ends as close as you can and you're golden.
The Following User Says Thank You to schlutzer For This Useful Post:
h0trod (02-11-2014)
post #6 of 6 Old 02-12-2014, 06:25 AM
CSIPSD's Avatar
Push them together???
Thats all I ever do, put your back into it and push them together...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
