ESOF to Floor Handle Swap - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-11-2014, 10:33 AM Thread Starter
GeorgiaStrokin's Avatar
Quoted: 8 Post(s)
tried searching existing threads and didnt find anyone who swapped from esof to 4x4 on the floor. i will swap the hubs to an aftermarket brand- NOT WARN. I see the plastic bolt in cover that covers the existing handle hole. will a handle/mounting hardware from a salvage truck be a bolt in swap? i can cap all of the vacuum lines to keep the defrost flapper option working.
GeorgiaStrokin is offline
post #2 of 10 Old 02-11-2014, 03:11 PM
Zaairman's Avatar
Quoted: 12 Post(s)
Its a totally different transfer case and you will also need to figure out the wiring.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 10 Old 02-11-2014, 08:00 PM
It's not a totally different transfer case. There are differences in the shifting of the case but there are actually almost identical cases. You would need to switch cases though. There has been talk of trying to convert an electric case to a manual one but I haven't heard anyone succeed doing it. At the price of the cases you'd be well off to buy a manual one install it and sell yours.
There isn't much wiring to figure out. Just get the wiring harness for the manual transfer case and replace the esof harness then remove the switch from the dash. I think I even have a harness here for a manual transfer case I would sell you for cheap. I have a manual case that functions fine but has a crack from an accident that caused an oil leak that I would sell you for cheap as well.
But bottom line is, find a manual case and swap it out.
Matthews is offline
post #4 of 10 Old 02-12-2014, 04:54 AM
ChiefRocka's Avatar
Everything I own has a manual T/C (Jeep & Zuk) besides my '02 F-250.
Is this style T/C really problematic ??
Is it affected by cold temps, or what ??
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #5 of 10 Old 02-12-2014, 06:27 AM
CSIPSD's Avatar
It IS a completely different T-case... Thats why they have DIFFERENT part numbers...
You can not convert an auto one to manual, you have to swap it out with a manual one.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 10 Old 02-12-2014, 06:39 AM
I guess we can agree to disagree. Of course they have two different parts numbers, they aren't identical but all the components aside from the shifting mechanisms are the same. The housings are even the same castings, the chains and sprockets are the same, the inputs and outputs are the same
To say they are "different" is correct but "completely different" just isn't correct. I would be willing to bet I could convert one from electronic to manual but at the price of the cases on the used market it just doesn't make sense.
On a side note, it sure does seem like you are good at making friends around here.
Matthews is offline
post #7 of 10 Old 02-12-2014, 07:24 AM
CSIPSD's Avatar
I could care less about making friends on line... I dont come to these websites to make friends I will never meet...
The case internals are different, there is no neutral setting on the electric case, which is the main reason its near imposable to convert one from electric to manual...
Joe
CSIPSD is offline
post #8 of 10 Old 02-12-2014, 08:02 AM
dannanw's Avatar
Quoted: 67 Post(s)
Garage
agreed...they're similar but diffrent and as far as the op is concerned the answer is that they're compleatly diffrent...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #9 of 10 Old 02-12-2014, 12:48 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
The best way to convert to manual is to swap in an NV-271 transfer case, it would be a bolt in swap.
But you can use a factory floor shifter and fabricate some of the linkage to fit your NV-273 transfer case, it will take some custom work, and you won't have a neutral position.
Here is info about what needs to be done: esof elimination build - Ford Truck Enthusiasts Forums - pictures are at the end of the thread!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #10 of 10 Old 02-12-2014, 12:52 PM
Quoted: 48 Post(s)
they are not problematic... biggest problem is in the actual hub actuation, but you can always manually lock them in
drunk on diesel is offline
