Replacment EBPVS tube - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-11-2014, 10:56 AM Thread Starter
gmat's Avatar
I cleaned out my EBPV sensor and tube the other day and it was very very clogged with soot. I cleaned out the sensor as best I could but I'm pretty sure there is still lots of junk in there. The tube was also packed full and I cleaned it out but noticed that there is a small hole and maybe a crack on the tubing.
So I was wondering where is a good/cheap place to get replacements from, including any bundle deals. The bracket/connecting piece (that the sensor screws into and the tubing screws into on the other side) is also very clogged and packed so hard that I could barely knock away a small air passage through the center. So I would like to replace that as well, though I couldn't find a place that sells that particular piece.
I have a 99 F350 CC LB 4x4. I'm not sure if my truck is an early or late 99. The build date on the door says 5/99 but I was reading up on it in another thread and I have the square U-bolts on my front axle and my radiator does not have the transmission cooler in it, it is a separate piece, which are both supposed to be signs that it is an early 99. Though the build date would suggest that it is a late 99.
Any help is much appreciated
1999 F350 4x4 Crew Cab Long bed. 240k miles and bone stock as of now. Looking to change that soon
gmat is offline
post #2 of 11 Old 02-11-2014, 11:28 AM
You can pick up the tube at Oreilly auto Dorman makes a replacement for sensor I would stick with OEM through one of the vendors on here. Done remember the size but you can use a drill bit to clean out the fitting. I would start with replacing the tube and trying the sensor especially if you have a CTS or AE that can monitor it to see if working.
As for E vs L99 easiest way to tell is look at your turbo compressor housing does it have 4 or 5 bolts if 4 you have E99, there are other items such as the AIH, Plenum size ect.. but the turbo is quickly and easily verified.
cory99 is online now
post #3 of 11 Old 02-11-2014, 01:42 PM Thread Starter
gmat's Avatar
I'm not sure what bolts exactly I'm looking for. Which side of the turbo?
Also I do have an AIH. I'm actually really curious to figure out which I have because I want to do a coolant flush and change over to ELC but from what I understand you cant do that if you have an early 99 because you will get leaks from seals or gaskets or something.
gmat is offline
post #4 of 11 Old 02-11-2014, 02:03 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
you have a late 99.
my trucks build date is 01/99, which means i have late model motor but early model front end parts. your truck is all late 99 parts. so you can use elc.
a new ebpv tube is only like 36 bucks on ebay, pretty cheap.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 11 Old 02-11-2014, 02:10 PM
Drives side of turbo. Not sure on coolant mine has green coolant in it and is probably time to flush it anyways so will be interested to see what others say on it
post #6 of 11 Old 02-11-2014, 02:38 PM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
NoRalPh is offline
post #7 of 11 Old 02-11-2014, 03:00 PM Thread Starter
gmat's Avatar
I was curious if anyone knew of any combo or bundle deals to get them cheaper. I heard that if the sensor is very clogged you should replace it.
gmat is offline
post #8 of 11 Old 02-11-2014, 03:03 PM Thread Starter
gmat's Avatar
Originally Posted by NoRalPh View Post
I read that thread, but my truck has parts that are both early and late 99.
gmat is offline
post #9 of 11 Old 02-11-2014, 09:13 PM
Quoted: 249 Post(s)
03/99 was the cutoff for early model frond end components. so 05/99 is all newer stuff.
no combo kit really, just dont buy from ford, they charge a lot
post #10 of 11 Old 02-12-2014, 06:16 AM Thread Starter
gmat's Avatar
Ok, Thanks.
On a side note, what does driving with a hole in the tube do? Like is it really bad on the engine, or just something that should get fixed sooner rather than later?
gmat is offline
