Mirror turn signal lights when brakes are applied - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-10-2014, 03:24 PM Thread Starter
HillbillyDeluxe39's Avatar
I wired my turn signal mirrors up yesterday and today I noticed they light up when I touch the brakes. I tied into the wires at the blinker switch in the column, tested them and they flashed left and right respectively
Which wires should I have used in a 2000 XLT?
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #2 of 4 Old 02-10-2014, 06:31 PM
Joel's Avatar
Quoted: 10 Post(s)
I Don't know what the correct wires are. Pull out a test light and probe until you find the one that's right.
I'd probably hook it to my running lights and forget about the turn signals, but that's just me.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 4 Old 02-10-2014, 07:39 PM Thread Starter
That's what I did, but I think the ones I tapped into are for the rear blinkers which is why they light up when I hit the brakes... not sure yet. Was poking around in there all evening but no luck yet. All the write ups I've found are for later years and the wire colors don't match. There's a lot of wires, I was just hoping someone with a 2000 had done this and knew the wire color/location.
2000 F250 CCSB 4x4
post #4 of 4 Old 02-16-2014, 08:38 PM
StrokinAlaska's Avatar
Tag brown behind your fusebox under the dash. Parking light positive trigger.
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
