Engine Wiring Harness Help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-10-2014, 12:12 PM Thread Starter
I'm in the process of putting the motor back into my truck and I need some help from you guys.
On the main engine harness theres an orange and black large gauge wire that comes off both the starter and glow plug relays and runs behind the A/C compressor. Theres a wire eye on the end of that wire. Where does it connect to?
Thanks in advance guys
208 F250 6.4 Lariat
4" Downpipe Back, AFE Dry Intake, EGR Block Plates, SCT Livewire TS with PIP tuning, 2.5" Level, 35 Toyo M/T
----SOLD---
2003 F250 7.3 XLT
6637, 4" Exhaust, 50 hp tune, Irate Regulated Return, HPx, Bellowed Up-Pipes, Boost Trans and EGT Gauges, 2.5" Level Kit, Sky Jacker Dual Stabilizers, 305/70r16 Fierce Attitude M/T
Nolooseends is offline
post #2 of 9 Old 02-10-2014, 12:14 PM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
picture? there's hundreds of wires on these...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 9 Old 02-10-2014, 12:44 PM Thread Starter
The one in my hand
208 F250 6.4 Lariat
----SOLD---
2003 F250 7.3 XLT
post #4 of 9 Old 02-10-2014, 12:48 PM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
I'm not in front of my truck but I'm thinking chassis ground, if no one else chimes in I'll look tonight (in about 4 hours).
dannanw is offline
post #5 of 9 Old 02-10-2014, 01:00 PM
7.3Lariat's Avatar
I'm thinking the same thing but I also do not have a truck to go look at.
______________________________________________
Mike
SOLD
Mods: BD-X monitor, 6637, BTS, GT38R, Snow MPGMax, International up-pipes, Hi-Flow Outlet, 5" Diamondeye, HPx, FRx, Gearhead tunes, Tru-Cool tranny cooler, Remote Start
376HP 791ft-lbs on 10.15.11
7.3Lariat is offline
post #6 of 9 Old 02-10-2014, 01:34 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 328 Post(s)
Positive post on passenger battery
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #7 of 9 Old 02-10-2014, 01:51 PM Thread Starter
I was torn between a ground or the positive post and I know I would have guessed wrong.
Ricemiester you can confirm that?
208 F250 6.4 Lariat
----SOLD---
2003 F250 7.3 XLT
post #8 of 9 Old 02-10-2014, 04:14 PM
LoxDiesel's Avatar
Quoted: 328 Post(s)
Glow plug relay is positive. And im assuming it goes to the alternator also. Most definitely positive. The only large grounds are battery terminal grounds. The rest are small or naked.
@loxdce
post #9 of 9 Old 02-10-2014, 08:01 PM
Machinist & Fabricator
h0trod's Avatar
Quoted: 28 Post(s)
Garage
Originally Posted by Nolooseends View Post
The one in my hand
I just took mine apart.
this is the only wire that leads to the passenger side fender?
if so...
it goes to the silenoid on the passenger inner fender , along with the main 12V + from battery.
h0trod is offline
