flickering lights - Ford Powerstroke Diesel Forum
Old 11-27-2006, 04:41 PM
flickering lights
my lights seems to flicker a little. just goes brighter, dimmer, at the sound of the motor... whats up? im talkign about itnerior lights, but it probably does it on the headlights too.
Old 11-27-2006, 04:57 PM
Probably want to have your batteries and altenator load tested and also check the battery terminals to make sure they are clean and tight
Old 11-29-2006, 06:13 AM
thanks for the reply
i checked the battery connection and they seem fine
i guess it has to be the alternator!
Old 11-29-2006, 06:57 AM
Conservative and Proud
Did you have the batteries tested?
Old 11-29-2006, 07:12 AM
If the batteries and alternator test good, then check that the headlights also change intensity. If they do not change, check your body ground (In many vehicles the interior lights are grounded through the body and the headlights are circuit grounded).
Old 11-29-2006, 08:11 AM
no, i did not check the batteries, but i did check the connection on the battery
i have not checked to see if the headlights change intensity, i will definately check that next time it does it. but i dont think they do now that i think about it, and the battery voltmeter is solid.
Old 11-29-2006, 08:22 AM
In checking the batteries, take the truck to autozone, NAPA... and have them Load Test the batteries, this can't be done without proper tools, and they will do it for free. While you are there, have them check out the alternator. They can test both of these in the parking lot, you dont have to take them off or anything, just drive it there and ask them to check it out. Its Free, and Easy, and the best way to test both items.
Old 11-29-2006, 12:38 PM
Cool Lights
you know, They could be flickering because it Chrismas season. Of all the vehicles I've owned, My diesels seem to need more maintanence. I have mine off a couple times a year and when I'm done I always se a change. Maybe every third oil change. Keep water in them and clean terminals, they get a hard pull when starting
Old 11-30-2006, 09:32 AM
yeah
the headlights does it too
all the lights do it
it shakes like it has an olddd points regulator
Old 11-30-2006, 09:40 AM
Did the tests say your battery and alternator were good?
