Boost... - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-09-2014, 04:30 AM Thread Starter
alexfisk19's Avatar
Boost...
What kinda psi should my stock 7.3 be pushing? The max I've gotten is 8. Just doesn't seem right to me.
alexfisk19 is offline
post #2 of 11 Old 02-09-2014, 04:36 AM
schlutzer's Avatar
Quoted: 18 Post(s)
You should be in the ballpark of 20 psi.
There are many factors in low boost. You need to check for boost leaks, major up pipe leaks, stuck ebpv. When I had a low boost condition it was because my ebpv had chucked the clip and the butterfly was free to move.
How does your turbo sound? Nice clean whine or is it more like an air hose in your exhaust
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 11 Old 02-09-2014, 05:02 AM Thread Starter
alexfisk19's Avatar
You can't even hear it. I'll check all that later this afternoon. The only time you can hear it is when the truck is at a high rpm and a low gear and you let off and it blows off
post #4 of 11 Old 02-09-2014, 05:08 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Okay so it just isn't building it.
You need to check for significant exhaust/boost leaks
post #5 of 11 Old 02-09-2014, 05:12 AM Thread Starter
alexfisk19's Avatar
What's the best way to check boost leaks?
post #6 of 11 Old 02-09-2014, 06:16 AM
03ranger30's Avatar
Get a boost leak detector to check the intake side of things, and get up under the truck and shine a light on your up pipes to see if there is any soot collected near the top of them where they meet the collector before the turbo.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #7 of 11 Old 02-09-2014, 07:04 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Best I got from a stock truck was 16 psi... but you still have issues to look for. Have you pulled the intake tube to look at the turbo wheel fins? Are the edges nice and sharp or rounded and/or jagged? Worth checking...
However... if you can't hear it whining it does sound like a 'drive' issue more than a 'compressor' issue.
Uppipe leaks are common... soot on the firewall and bellhousing is what you will see.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #8 of 11 Old 02-09-2014, 11:51 AM Thread Starter
alexfisk19's Avatar
Both sides of the wheel housing are leaking oil. The line on the wastegate is soaked in oil. And fins look ok. And then all the intercooled lines I believe on top of the valley are soaked in oil.
post #9 of 11 Old 02-09-2014, 12:17 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
could be leaking from turbo, pedestal/ebpv actuator and the boots are probably soaked from ccv venting into the intake.
blue99stroker is offline
post #10 of 11 Old 02-09-2014, 12:41 PM Thread Starter
alexfisk19's Avatar
See I also Dont know all those parts.... I know what they are. Just not where they are.
