| View Poll Results: running uls diesel fuel | |||
| no |
14 | 30.43% |
| yes with nothing else |
10 | 21.74% |
| yes but with a fuel lube |
22 | 47.83% |
| Voters: 46. You may not vote on this poll | |||
uls diesel fuel
How many have been running it and have you noticed any problems? If you are running if are you adding a fuel lube or not? I ask because its getting harder to find the old stuff around here.
I've been running it since last month when it became mandatory here. I have had the oring seals on my fuel filter start leaking. I don't know if it was related to the new fuel but, I never had them leak before. And it wasn't like I just changed the filter either.
What about an answer that says "I don't know" ahah...
Ive ran 2 tanks of ULSD....both tanks were like 30-50 miles less than what i normally get, didnt really notice a power loss, just MPG
http://www.blueridgediesel.com/CUMMINS%20TSB_082905[1].pdf
This URL talks about leaks that are caused by the ULS Diesel. The nitrile membrane normally soaks up the LSD and swells to seal the pump. With the ULSD, the membrane shrinks and allows leaks. Is this what happened to you? |
It is advisable to use and booster of some sort when using ULSD. Just FYI
And Blasater Welcome aboard
Too early to tell.....
Have always used PowerService in the winter, but now with the decreased lubricity of ULSD, I plan on making up the DocB special medicine RX: Summer: Silver PowerServive + HowesLube Winter : White PowerService + HowesLube Anyone know if there would be a problem putting both in the same bottle? |
I have an '04 PSD 6.0 with AFE Magnum Force Stage 2, The Edge w/ Attitude, 4X4, Long Bed and a few other goodies. What brand of diesel treatment do you recommend for use with the ULSD?
Blaster!How about vegi oil as an additive...it's very libricating!
ULSD is all that is available here, i do try to use B5 biodiesel as well to help with lubricating as well, still use an additive. right now trying the ford product but still noticing a drop in mpg, about 2 mpg. going to switch to Power Service after done with the ford stuff.
