Fuel bowl removal questions - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-07-2014, 03:43 PM Thread Starter
My 2001 ford f250 has been leaking fuel from the fuel bowl ever since I bought it. I purchased o-rings to re-seal the entire fuel bowl. When I first started this project I got to taking the bolts out from the front of the HPOP reservoir and my ratchet was too big to remove the bolts so I had to go get a new ratchet. I bolted everything up so no dust or dirt got in the system and ended up breaking the FPR threading so I ordered a billet one and got it in today. On every video online of people removing the bolts for the fuel bowl the EBPS is not in the way, but I can't get to the bolt. Has anybody else had this problem and if so how to do go about getting the bolt out?
Thanks.
[IMG][/IMG]
2001 Ford F-250 crew cab 4X4 Green and Tan
BamaBoydFORD is offline
post #2 of 14 Old 02-07-2014, 05:57 PM
I just did the bowl on my truck that bolt was a pita. I used a 1/2 ratchet wrench to get the bolt loose. After removing all the other connections to the bowl I just let the bowl move away from the hpop reservoir ale left the bolt though.
Baddak is offline
post #3 of 14 Old 02-07-2014, 06:01 PM
Joel's Avatar
Quoted: 10 Post(s)
That's exactly what you do. Leave the bolt in place and remove the bowl
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 14 Old 02-07-2014, 06:15 PM Thread Starter
Thanks y'all, I'll try that tomorrow. How did y'all loosen the bolt though? I can't even get my socket on it.
post #5 of 14 Old 02-07-2014, 06:29 PM
I used a ratchet box end wrench on mine.
Baddak is offline
post #6 of 14 Old 02-07-2014, 06:35 PM
Joel's Avatar
Quoted: 10 Post(s)
And if you don't have one of them just a regular old wrench will do it.
Joel is offline
post #7 of 14 Old 02-07-2014, 06:38 PM
Yea it will just will take a bit longer.
Baddak is offline
post #8 of 14 Old 02-08-2014, 03:51 AM
Solid98's Avatar
Quoted: 9 Post(s)
I just unscrew the back pressure sensor. Bolt comes right out.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #9 of 14 Old 02-08-2014, 06:07 AM
blue99stroker's Avatar
Quoted: 270 Post(s)
ya remove the ebpv sensor and the bolt is easy to get too...
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #10 of 14 Old 02-08-2014, 12:21 PM Thread Starter
I got the fuel bowl out but now my problem is the FPR threads are in the nut on the fuel line and I can't get the fuel line out of the truck. I spent 2 hours trying to get it out and I can't do it. Does anybody know a way to get the threads out of the nut?
