Did I just get ripped off??? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-07-2014, 12:17 PM Thread Starter
HillbillyDeluxe39's Avatar
So I purchased a Delphi HTS101 CPS on amazon, it shows up to day and I am surprised to find what looks like a grey Ford CPS.
I was under the impression the Delphi would look like a black ford CPS.
What do you think? Am I being played?
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #2 of 15 Old 02-07-2014, 12:31 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
You didn't think, just because it was Black, it would be anything like the Ford, Black, CPS?
I mean, it's just the color of the plastic they choose...
I think, with all the trouble people have had with aftermarket CPS's, I would stick with either Ford or IH. It's not like they're expensive anymore
NoRalPh is offline
post #3 of 15 Old 02-07-2014, 12:46 PM Thread Starter
No.
I have been through two CPS's Ford Grey (failing), BW (caused Horn/Wiper issue), and now trying a Delphi. All the stock photos online so the Delphi with the big/fat magnet end, black in color with the Gold mounting plate. I am awfully suspicious that it showed up with a skinny end, grey with a silver mounting plate - same as a Grey Ford CPS, which is not what I ordered.
2000 F250 CCSB 4x4
post #4 of 15 Old 02-07-2014, 03:15 PM
Quoted: 157 Post(s)
The Grey ones "go-out" on you? How long do they last? That's pretty strange...
How about IH?
Here's all the numbers I have, maybe another one would work better but, I'm not sure why the Ford Greys won't
Recall Grey CPS
Ford: F7TZ-12K073-B
IH(equivlant): 1876735C91
97-03 original CPS (black): Ford Part # - F7TZ-12K073-A, corresponding IH Part # - 1825899C93
97-03 updated CPS (grey): Ford Part # - F7TZ-12K073-B, corresponding IH Part # - 1876735C91
IH DT466 original CPS (blue): IH Part # - 1807339C92
IH DT466 updated CPS (grey)*: IH Part # - 1885812C91
NoRalPh is offline
post #5 of 15 Old 02-07-2014, 04:30 PM
kystanger's Avatar
Your not the only one, I order the Delphi cps a couple months ago and when it arrived it is ford grey cps. I had the grey one in my truck and when I pulled it ever number and marking on it matched the Delphi. I don't know what the deal is.
2008 f350 4x4 Stock
(SOLD)2001 f250 4x4
319,000 miles and counting.
6637 intake, 4 inch MBRP exhaust,gauges,203 degree therostat, leveling kit, transgo tugger kit, front and rear mag-hytec diff covers, more to come.
kystanger is offline
post #6 of 15 Old 02-07-2014, 05:06 PM
alaskan155's Avatar
Quoted: 60 Post(s)
because ford doesn't make most sensors and parts, there distributor might be delphi for the sensor
i know its BERU for the glow plugs
and bosch for the fuel injectors,(gas)
when it comes to sensor and certain things ford outsources, if you want i can look at my new ford gray i have in my glovebox and see what info is on the sensor itself.
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #7 of 15 Old 02-07-2014, 05:28 PM Thread Starter
Sure, the numbers on my "Delphi" are 3k26 and 1876735091
2000 F250 CCSB 4x4
post #8 of 15 Old 02-08-2014, 06:12 AM
blue99stroker's Avatar
Quoted: 260 Post(s)
delphi is grey and small but it is not the ford cps.
my truck runs way better than when i ran the ford recall cps.
ive tried two grey recall cps, a blue int'l cps, and the borg warner cps.
the borg warner cps ran great but i also had wiper issues, so i switched to the delphi and am really happy with it.
no more erratic idle the tuck runs great
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
The Following User Says Thank You to blue99stroker For This Useful Post:
HillbillyDeluxe39 (02-10-2014)
post #9 of 15 Old 02-10-2014, 03:17 PM Thread Starter
blue99stroker, I swapped it out and it they are identical, even had the same numbers. It does idle better so I'm run with it and see how it goes, Thanks for your input.
2000 F250 CCSB 4x4
post #10 of 15 Old 02-10-2014, 03:38 PM
gone6.0's Avatar
Quoted: 25 Post(s)
Yes delphi makes alot of stuff for ford. My engine has at least four parts that are factory that say delphi on them. That I have found.
2004 F250, SCSB, APR studs, Banks intercooler, Edge Insight, SCT with tune from Eric, atlas 40, deleted, 2" leveling kit, coolant filter, 6.4 banjo bolts with blue spring, Harpooned, Nathan K5LA. Nations 190 amp alt.
Twin Viair 480C's. BOSS superduty 8' poly plow.
gone6.0 is offline
