Injectors - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-07-2014, 05:29 AM Thread Starter
Injectors
I have an e99 that has number 8 Injector bad I have been advised that I should just replace All for Injectors on that side as long as I am there. Now from my understanding the later model 7.3 has a large flow Injector is it OK to use the latter model on my e99 if I am just replacing the four Injectors on one side?
jaybirdys is offline
post #2 of 3 Old 02-07-2014, 09:22 AM
No you have to have all the same injectors. If you replace the four on the drivers side with the later model, you need to also replace the injectors on the passenger side with the same injectors. Also the number 8 injector failure is pretty common. More then likely the other 3 injectors on that side are fine. I would just replace the number 8 injector with an injector from the same year, which would be AB.
powersmok is offline
post #3 of 3 Old 02-07-2014, 10:05 AM Thread Starter
Thanks for the info powersmok some more research into the number eight deal and you just saved me the cost of three Injectors thanks again
