Ceramic Coat or Exhaust Wrap - Up-pipes - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-06-2014, 03:06 PM Thread Starter
03ranger30's Avatar
Bought a set of used bellowed up pipes from a member on here. I want to either ceramic coat them or wrap them in exhaust wrap before I put them on. Obviously the wrap is probably easier and the coating probably looks better, but which actually holds heat better and will last longer?
I am also looking to do my IC pipes the same way, obviously those don't fit in my oven though so I will probably wrap those.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #2 of 6 Old 02-06-2014, 03:11 PM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
I asked a local performance shop that same question a few months back and he told me that if you wrap them, there is a possibility of the wrap being soaked in oil/diesel fuel if there is a leak in the engine valley and that would cause a significant fire hazard in his opinion. Wrapping the down pipe didn't cause the same concern in his opinion.
384,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
The Following User Says Thank You to 7.3Excursion4x4 For This Useful Post:
03ranger30 (02-06-2014)
post #3 of 6 Old 02-06-2014, 03:14 PM Thread Starter
03ranger30's Avatar
If I did the ceramic coating I would use the stuff that VHT makes. It says to either bake them in the oven or let them bake while they are on the truck running. If I baked the up-pipes in the oven would it be bad for it? I mean this is the same oven that we cook in. The one video I watched said it would leave an odor in it after I was done.
Charlie
post #4 of 6 Old 02-06-2014, 06:13 PM
Quoted: 14 Post(s)
I'd be worried about the pipes burning out if wrapped. That would just trap all the exhaust heat inside. If they are made out of 304SS or Inconel, they would survive, but I'm not sure mild steel would hold up.
ttyR2 is offline
post #5 of 6 Old 02-08-2014, 07:13 AM
blue99stroker's Avatar
Quoted: 246 Post(s)
my friend had his ceramic coated and we cant tell the difference in egts at all...
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #6 of 6 Old 02-08-2014, 07:15 AM Thread Starter
03ranger30's Avatar
Yeah I figured it wouldn't make much of a difference. Just wanted to clean them up a little bit.
Charlie
