Battery/Alternator/Wiring question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-06-2014, 06:29 AM Thread Starter
Quickhorse's Avatar
Batteries are 1 year old from Ford . . . Alternator is the upgraded 3g or 6g case whatever it is with a smaller pulley and is about 3 years old. While plowing, after a couple lots the lights start dimming and all kinds of gauges coming on because of the batteries getting run down. Low RPM's combined with high amp draw from plow cause the alternator to not be able to keep up for some reason. I never had this problem before so I'm not sure what it is. i put a new plow pump motor on, cleaned connections, etc . . . still no luck.
I have a trickle charger bolted onto the one battery and a 3 prong plug sticks out front for easy charging. I thought maybe a regulator problem with the alternator . . . or I see that the big wire goes to the GPR (glow plug relay) then over to a starter solenoid and finally to the passenger side battery.
Seems like a long way to travel for charging? Should or can I run a bigger like 1/0 wire directly from alternator to the driver's side battery??
2008 F350 CCSB FX4 Amsoil fluids, S&B intake, 5" exhaust, Egr delete, Boss V plow, Mega Duty Title mod.
Quickhorse is offline
post #2 of 9 Old 02-06-2014, 06:57 AM Thread Starter
Quickhorse's Avatar
Well, I'm about to buy an alternator off ebay that says its a 250amp. I know I'm just throwing parts at it but I need the truck for plowing and can't have down time like this. I couldn't find one at any of the parts stores that was upgraded in amperage and there's no sense in going back to a stocker . . .
post #3 of 9 Old 02-06-2014, 06:58 AM
schlutzer's Avatar
Quoted: 18 Post(s)
That's actually a fairly common thing to do. You must leave the stock wire but you can add your own.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 9 Old 02-06-2014, 07:10 AM Thread Starter
Quickhorse's Avatar
Could the alternator be drawing power somehow when the truck is off? I want to make sure I'm not wasting money. The batteries go dead if the truck sits for a few days so something is drawing and i've triple checked everything . . . could it be the alternator causing all of this. Not producing enough at idle or even at higher rpm and something inside it is bad causing a slow draw when truck is off?
post #5 of 9 Old 02-06-2014, 07:12 AM Thread Starter
Quickhorse's Avatar
There's not really enough room on the stud but I'll try to figure something out. Thanks for the reply . . . i really need to get this figured out ASAP.
post #6 of 9 Old 02-06-2014, 07:32 AM Thread Starter
Quickhorse's Avatar
I just bought a 250 amp alternator . . . ships in Saturday.
post #7 of 9 Old 02-12-2014, 07:12 PM
wynn456's Avatar
if the diode in the alternator goes bad it will cause a battery draw.
wynn456 is offline
post #8 of 9 Old 02-13-2014, 08:04 AM Thread Starter
Quickhorse's Avatar
Well, ended up putting the new 250 amp alternator in and all I can say is wow what a difference. Not to mention my lights don't even dim when using the plow b/c I am producing 13-14volts at idle. The pulling is noticeably smaller on the new alternator. Very good quality, great packaging when shipped and insanely fast shipping. I order the thing on ebay last thursday and had it at my house on Saturday from California with free shipping. Let me see if I can find a link to one they are selling in case anyone else needs one. I am going to go to the hardware store and get some 4g cable and copper ends to run a wire to the drivers side battery still. I think that is a good idea.
post #9 of 9 Old 02-13-2014, 08:07 AM Thread Starter
Quickhorse's Avatar
High Output 250Amp Alternator Ford Ranger Explorer F Series 4 0 4 2 7 3 V8 92 04 | eBay
