Old 08-22-2005, 01:51 PM
RodM RodM is offline
Truck Dies 7.3L PS
1997 PS Crew Cab 7.3L When I apply my trailer brakes through the controler slider bar the truck instantley dies, The truck also dies perodicaley when the drivers door is opened.
Have isolated the trailer from the truck and the same thing happens when the slider is slid to full brake position.
Has anyone else experienced a similar problem as this one.
Old 08-22-2005, 03:45 PM
Andy Andy is offline
Administrator
That is a wierd one. Anyone got any ideas?
Old 08-28-2005, 09:39 AM
Ronny'02-7.3 Ronny'02-7.3 is offline
Rod, does thr truck have any starting problems? Could there be a bad battery or alternator connection?
Old 08-28-2005, 09:40 AM
OOPS. "The" truck. I would also check grounds to the body. Bad grounds do strange things.
Old 08-28-2005, 11:00 AM
Harley Truck Harley Truck is offline
Send a message via AIM to Harley Truck
wow that is a weird issue, i wish i could help ya. although like he said i would say check your battery, alt, grounds etc... having you taken it in anywhere to have it diagnosed? if so, what did they tell you>?
Old 08-30-2005, 05:34 AM
Have not Taken it anywhere
It has been an anoyence I really did not have time this weekend to work with it. I just drug may camping trailer up the canyon without it plugged in.
Old 08-30-2005, 09:13 AM
Rodslinger Rodslinger is offline
Gun Nut
That REALLY sounds like a ground problem.
Old 12-01-2005, 04:52 PM
bumbleG bumbleG is offline
diesels are notorious for demanding a good ground...
new brain, batteries and fuel pump made me a believer
Old 12-01-2005, 05:53 PM
Mike OB Mike OB is offline
My Guess is you have the power supply to the brake control connected to the IDM power supply and you are grounding the injector driver when you apply the brakes. Tomarrow I will pull up the wire diagram and see what else might do that. Mike OB
