Viable 7.3 swaps - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-05-2014, 08:47 AM Thread Starter
Machinist & Fabricator
h0trod's Avatar
Quoted: 50 Post(s)
Garage
Viable 7.3 swaps
Hello!
first off,
I have been a F series owner for the past 15 years, with GAS trucks.
I AM A DIESEL ROOKIE!
I know ill catch some shat for being a noob.
dish it out, I can take it.
I have recently purchased a 01 F250, 7.3L powerstroke, and a 4R100 automatic trans. crew cab, 4wd shortbed.
(stole is more like it)
the previous owner overheated it.
He did not know the damage it caused, so I jumped right into it, replaced the fuel bleed off valve, installed new batteries, and tried to crank it over. the only thing I got was diesel into my cooling system.
instead of replacing the heads, I want to do a complete swap.
I have found a 2002 7.3, that has been sitting in a garage for about 7 years.
40k miles on a F250 2WD.
I was told that the truck ran perfect, and the transmission took a crap. however the fact that the truck has been sitting for that long makes me crindge.
this guy wants 3500 for the complete engine minus turbo.
which the turbo has been taken off and again been sitting for X number of years.
What are your guy's thoughts on an engine that has been sitting for this long?
I appreciate any insight!
Thanks, and have a great day!
h0trod is offline
post #2 of 5 Old 02-05-2014, 09:21 AM
MSTR-P's Avatar
That is a chunk of change...especially minus the turbo. I would look elsewhere.
'03 7.3 - Stock!
MSTR-P is offline
post #3 of 5 Old 02-05-2014, 09:37 AM
Rodslinger's B1TCH
Pull the injectors out of the engine that's in there now. It might just need injector cups.
steve604 is offline
post #4 of 5 Old 02-05-2014, 11:08 AM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
You can definitely do better on the price. I bought a complete running 7.3 with turbo and everything that bolts to the block for $250. Just have to be patient and have friends looking out for you. Make friends with wrecker drivers!
410,000 miles
PHP Hydra Mishimoto Radiator
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #5 of 5 Old 02-05-2014, 11:14 AM Thread Starter
h0trod's Avatar
Quoted: 50 Post(s)
Garage
I bought another set of heads, they are in the machine shop getting injector cups in them right now.
I initially thought of just swapping heads, but I want this thing reliable as can be. my fear that the lower end may have some issues with it.
I cannot get the truck to fire at all. but I guess with all the fuel going into the cooling system, it is not getting the required fuel to get it to fire.
am I incorrect?
this isn't like my '71 F250 lol
h0trod is offline
