410 rear end need to change to 373... Opinions - Ford Powerstroke Diesel Forum
post #1 of 22 Old 02-05-2014, 01:03 AM Thread Starter
bburt85's Avatar
Hello, I am fairly new to the forum, I just bought a 2003 7.3 L crew cab duly F350. I have 410 gear ratio in the backend, and I am assuming it is the same for the front? Drove it home and 65 mph at 2600 rpm was horrible. I need to get better gears in the back end for highway speeds. Does anybody have any opinion where I should start with this? Should I go buy new ring and pinion gears and do it myself? Would it be easier to just find someone to trade axles with? Or would it be easier to take it to a diesel shop and have them do it? Thanks in advance for any help!!!!!
bburt85 is offline
post #2 of 22 Old 02-05-2014, 01:33 AM
blue99stroker's Avatar
Quoted: 247 Post(s)
2600 rpm at 65 seems high for 4.10's.
im not 100% sure though.
at 70 mph with 3.73's im at 2000 rpm
blue99stroker is offline
post #3 of 22 Old 02-05-2014, 01:37 AM
1BADTON's Avatar
Take it to a shop and have new gears installed. Unless you have the right torque wrench and know how to set the lash on the pinion.
1BADTON
01,Lariat CCLB, 7.3L, 8" Donahoe on 37"s, John woods, ARBs, 4:88, Hansen's frt&rear, 15k Warn, HID's, DP Tunr 80econo, banks cooler, adreniline, msd dpi, optima's, autometers, more to come?
1BADTON is offline
post #4 of 22 Old 02-05-2014, 03:57 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Best bet is to find somebody who wants the opposite, and trade them.
I bet youll be 2000$ to have to gears swapped for 3.73's.. but you can swap axles easy
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 22 Old 02-05-2014, 04:17 AM
Zaairman's Avatar
Quoted: 12 Post(s)
Changing your gears isn't something I would recommend DIY-ing, unless you have a hell of a shop. This will also cost you $1500-2000.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #6 of 22 Old 02-05-2014, 04:24 AM Thread Starter
bburt85's Avatar
So does anyone know a good diesel shop in the Twin Cities Minnesota area preferably on the Eastside? How much do you think this will cost?
bburt85 is offline
post #7 of 22 Old 02-05-2014, 04:26 AM Thread Starter
bburt85's Avatar
Just saw the cost in Zaairmans post. Thank you!!!
bburt85 is offline
post #8 of 22 Old 02-05-2014, 04:45 AM
Like others are saying, I'd find someone with bigger tires that would want to swap. I can almost guarantee you could find someone that would jump at the chance!
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #9 of 22 Old 02-05-2014, 06:03 AM
WVRidgeRunner's Avatar
I'm running the same gears with 245s on my dually and only turning 2300 at 70 mph. I reckon it could be the few mods I have to the engine making power at a lower RPM, not sure. I'd sure like to get mine to drop below 2k rpm, it'd make a lot better highway ride. Ring and pinion isn't that hard to change, but it MUST be set up right. Too loose, you break something; too tight, rear end will get hot and lock up which can be rough or deadly at interstate speeds. You have to have a good torque wrench, marking paint, a press, some type of puller, and a dial indicator in addition to normal stuff. Swapping axle assemblies is much simpler, I'm just not sure how easy it'd be to find dually axles with higher gears installed.
1999.5 707 Conversions Super Duty 7.3 Crew Cab LB Dually 4x4 Edge Evolution, Oil HPx, Fuel FRx, tons of filters, hutched n harpooned, B&W turnover ball and 5th wheel, lotsa goodies.
WVRidgeRunner is offline
post #10 of 22 Old 02-05-2014, 08:40 AM
7.3LDriver's Avatar
Quoted: 5 Post(s)
Since your truck is a 4x4 wouldnt putting the 3.73 gears in the back make those tires spin faster than the front tires when in 4wd?
E99 F350 eclb drw 7.3L 4X4
220,000miles
leveling kit
35" tires
Donaldson Replacement 6637 Filter
Diamond eye 4" TB
ts6 with informant6 monitor
180/30 full force diesel injectors
d66 turbo
Riff Raff HPX and FRX
valair clutch
Zoodad Mod
Cam-locker toolbox
7.3LDriver is offline
