2000 F350 GEM problems/questions - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-04-2014, 04:39 PM Thread Starter
The GEM has been acting up for the last few months. MY blower motor would come on with no key in ignition,battery going dead fast, interior lights staying on, etc.
This problem would come and go and wouldnt shop up sometimes for weeks.
I decided to replace my Gem. I have called many companies in cluding ford and they all say my unit has been discontinued.
My truck is 7.3,2wd,power windows,automatic and I never had a remote button so I dont know if it came from the factory with this option or not.
My questions are does anyone know where I can get one?
Or, can I use a GEM from the same year truck that has a few extra options? I think that there wouldnt be wires in plug in for these options so they wouldnt even be hooked up. I have access to a one from a 2000 F250 2wd.
The numbers on my GEM are F81B-14B205-BH
Your help will be appreciated
Thumper876 is offline
post #2 of 6 Old 02-04-2014, 04:57 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Have you looked at these guys? They seem to say, with your GEM ending in BH, that they have it...
Ford GEM Modules Auto Parts Cheaper Blog
NoRalPh is offline
post #3 of 6 Old 02-04-2014, 05:00 PM Thread Starter
I called them today. They say it is discontinued. Thanks for the reply
post #4 of 6 Old 02-04-2014, 05:08 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I did a bit of learning about the GEM when I did my power window upgrade.
You are kind of correct. You can get a GEM from another truck Late99-01 same configuration as yours. In my picture my GEM is the same as yours except its BD instead of BH, and the truck was a ext cab 4x4 6speed. Also from a 2000.
Left side is my old XL, manual everything, right being the one for the power options. The A had only a few spots for plugs, where the B has 3 plugs that go into it.
You have to remove the fuse box anyway ( like in my picture) so I would just get the whole thing from the scrap yard and go from there.
So yeah, another gem from a L99-01 *should* work just fine, with 99 you may run into the problems I did with my power window swap
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 6 Old 02-05-2014, 07:01 AM Thread Starter
Thanks for the info Shultzer.
I am going to have to try a GEM from a 2000 F250 unless anyone else has suggestions.
I am unsure why someone like Auto parts cheaper wouldnt know that a GEM with more options would work fine. When I called the rep knew all of these numbers by heart. It seems they get asked for this one on a regular basis.
Another question is f this truck has remote entry is the wireless receiver in the GEM? maybe I can have wireless entry?
post #6 of 6 Old 02-05-2014, 12:55 PM
schlutzer's Avatar
Quoted: 18 Post(s)
It shouldn't have to be a 2000, a L99->01 should work for you just fine. 4x4 and radio is controlled by the gem to so make sure you count them in as options
And to tell if your truck has keyless entry:
Get in shut the door
Turn the key back and forth between run and off 8 times if your locks cycle you have keyless
Adding it with factory stuff if you don't isn't worth it, you have to pull the dash to do it right
