Antifreeze help!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-03-2014, 07:46 PM Thread Starter
Antifreeze help!!
Ok so I just replaced my water pump and was refilling everything when i ran out of normal ethanol glycol coolant 50/50 and my buddy said he had some coolant in his truck by this time it was dark. I only need about 3/4 of a gallon to refill my system and when I was done I looked at the antifreeze and noticed it was orange and did some research saw that you ARE NOT SUPPOSED TO MIX. Am I going to have to drain my whole system for my 3/4 of a gallon of DEXOL aka ORANGE ANTIFREEZE added to Green ANTIFREEZE I added or should i Be Fine Not going to drive till I get a good answer please HELP!!
Ford4x4Hunter is offline
post #2 of 3 Old 02-03-2014, 07:48 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
If it doesn't say compatible with all antifreeze then drain it. No point in taking a chance IMO
dhanna6powerstroke is offline
post #3 of 3 Old 02-03-2014, 07:53 PM Thread Starter
DEXOL is OAT Based (Organic Acid Technology) this is the only difference
and Regualar 50/50 is Universal/Global Coolant
Both are Ethylene Glycol
Tags
antifreeze , orange to green add , please help
