fuel bowl leaking now and now im on vacation - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-01-2014, 05:46 PM Thread Starter
Quoted: 2 Post(s)
So a week and no leaks and all the sudden tonight it starts to leak. 2 days into my vacation 6 hours from home.
Its dark now and all I have is my cell light is all have. I can see it looks like a steady drip from under the plug on the back of the bowl. The bowl heater i believe. 2 questions and hopefully in the morning i can do something. There is a napa close by.
1 is this plug piece philips or torx? I remember taking it off. I dont have the directions right now.
2 what are the odds the o ring busted? Hopefully I can snug up the screws and be good...
thanks
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-DieselSite Transmission Filter
--W/ Guage and Flush valve
-Factory Tech Valve Body
-Stage 2 Snow Performance Water Meth
-AFE Blade Runner Intake Manifold
-TurboMaster WasteGate Control
-DieselSite Boost Relief Valve
-AIH Delete
-Garrett High Flow Outlet
-Garrett NON-EBPV Pedestal
-Plenum Inserts
-Torque Converter Lock Up Switch
cesspool is offline
post #2 of 5 Old 02-01-2014, 05:57 PM
usteffenhagen's Avatar
I'm leaning towards o ring
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #3 of 5 Old 02-01-2014, 06:23 PM Thread Starter
Quoted: 2 Post(s)
So we were out at a restaraunt. I literally watched it leak. Steady. Like I was concerned it would fill the entire valley and spill over on the way to the cabin and driving up the mountain it was dripping so fast.. I cleaned it with some papertowels and drove straight here. Get out when I got back to clean it out again with more papertowels and try and see if they were torx or philips. No leak. Small puddle from what I watched at the restaurant. Im 100 percent sure it was coming from the plug housing. I watched it drip. I could see it clear as day hit the puddle. the smell was bad in the cab. Now nothing.... im seriously going to go nuts with this erratic leaking....
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-AIH Delete
-Plenum Inserts
cesspool is offline
post #4 of 5 Old 02-01-2014, 07:01 PM
hansel's Avatar
Quoted: 94 Post(s)
Are you talking about the fuel bowl drain valve leaking?? That uses torque head wrench to get off, if it's something else leaking I'd need to go look at my truck to see what your talking about.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #5 of 5 Old 02-01-2014, 07:31 PM Thread Starter
Quoted: 2 Post(s)
Its the part the bowl heater plugs into
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-AIH Delete
-Plenum Inserts
cesspool is offline
