drain or not - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-31-2014, 02:39 PM Thread Starter
miked.'s Avatar
drain or not
quick question. do i need to drain the oil before i remove the oil cooler. i kno the coolant needs to be drained. just wandering. trying to save some time. will change oil but not right away.
miked. is offline
post #2 of 3 Old 01-31-2014, 03:40 PM
Quoted: 780 Post(s)
I believe if you just remove the filter most of the oil will drain out of the cooler. Easiest way to drain the coolant is to remove the block heater element. Drain into 5 gal bucket.
Have you ever had feelings for a nun??? "Nacho Libre"
Corey@CNCFAB is offline
post #3 of 3 Old 01-31-2014, 09:01 PM
The pan is lower than the cooler so the answer is no.
Greenman01 is offline
