New Turbo - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 01-31-2014, 09:37 AM Thread Starter
New Turbo
Hey guys I want to get a 38r for my 2003 f250. Ive heard you only get around 30 extra hp with stock injectors. Would you get more hp if you upgrade to stage 1 injectors? Also, will the 38r fix turbo surge?
Nathan_Mussell is offline
post #2 of 13 Old 01-31-2014, 09:38 AM
shenanigans
junior125's Avatar
Quoted: 1492 Post(s)
Garage
99-03 7.3L General Discussion - Ford Powerstroke Diesel Forum
You've posted in the introduction center, unfortunately only Moderators can move posts, the link above would be a good place to post your question, someone there should be able to help
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, ODAWG S3R, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is offline
post #3 of 13 Old 01-31-2014, 09:41 AM Thread Starter
ok thanks man im still trying to figure this stuff out I just joined a couple of days ago
post #4 of 13 Old 01-31-2014, 09:47 AM
shenanigans
junior125's Avatar
Garage
in that case, hopefully you get your issues figured out
Mike
2005 CCSB F250 4X4
post #5 of 13 Old 01-31-2014, 09:48 AM Thread Starter
New Turbo
Hey guys Ive just put in an afe air intake, 4 inch turbo back straight pipe, and a chip from dp tuner. Im thinking about getting a new turbo pretty soon. Ive been looking at the gtp38r and have seen some pretty good reviews, but ive also read that it will only give you around 30 hp. If I get bigger injectors will I get more hp from the turbo? Also, ive been experiencing what I think is turbo surge will the 38r fix turbo surge? Im clueless when it comes to this stuff so please give me all the advice you have. Thanks!
post #6 of 13 Old 01-31-2014, 10:03 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 897 Post(s)
Feedback Score: 6 reviews
Moved and merged your threads and to the ORG.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #7 of 13 Old 01-31-2014, 11:03 AM
Justin@DP-Tuner's Avatar
Quoted: 51 Post(s)
With stock injectors, you may not see any HP gain at all by just adding the GTP38R. The turbo isn't really there to create power, but instead to support it. It does definitely move more air, eliminate surge, and is louder than the stock turbo, but you will not feel a seat of the pants difference.
Matching the GTP38R with a set of 160/30 injectors will for sure give you a bump in power which you can feel. That is the perfect combo for an otherwise stock truck in my opinion.
We can get you setup with the turbo and injectors if you are interested. Feel free to contact me with any questions.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is online now
post #8 of 13 Old 01-31-2014, 11:34 AM
CSIPSD's Avatar
38R is a fine turbo, it would be well matched with a set of stage 1's... However I would look at a Brute 66 from Dynoproven or even just a billet compressor wheel from Riffraff diesel...
That wheel right there and a set of P.I.S 160/30's would put you right at 400hp...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
Last edited by Rattlesnake18; 01-31-2014 at 11:45 AM. Reason: Removed links to non-supporting vendors
CSIPSD is offline
post #9 of 13 Old 01-31-2014, 12:37 PM
Quoted: 762 Post(s)
I sure wish people wouldn't say stage 1 or 2 or whatever. Hehe. That record sound familiar?????:what:
Joel likes this.
Corey@CNCFAB is offline
post #10 of 13 Old 02-01-2014, 08:00 PM Thread Starter
Ok ill have to learn how to use the right threads I think I have it figured out now. If I were to get bigger injectors with the 38r would I have to upgrade my transmission? Could I just get the trans command from banks or would I have to get a whole new torque converter?
