What oil to use - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-31-2014, 07:28 AM Thread Starter
What oil to use
I am new member. Thanks for any help you all may give me. I have 99.5 power stroke. F250. 205k. 6 speed. New gp/gpr. New batteries. Still has some trouble starting in cold. I am due for oil change. Should I stick with 15w-40. Or go to 5w-40. Or possibly 15w-40 blend.
trob99 is offline
post #2 of 12 Old 01-31-2014, 08:21 AM
CSIPSD's Avatar
Define cold...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 12 Old 01-31-2014, 10:55 AM
schlutzer's Avatar
Quoted: 18 Post(s)
I run 15w40 during the summer months.
10w30 DIESEL oil in the winter. Not regular old 10w30 oil for a gas engine, must be diesel rated.
I don't know how cold it is for you but we average -20*C in winter here. My Ford manual says 10w30 for when the average temp is less than -5*C. Switching to lighter oil makes a profound difference
Or you could go synthetic and run 0w40 year round. But don't switch back and forth between synthetic and dyno. Pick one and stick with it.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 12 Old 01-31-2014, 11:44 AM Thread Starter
So is 0w-40 or 5w-50 ok to run year round and which would I want?
trob99 is offline
post #5 of 12 Old 01-31-2014, 11:56 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Who said anything about 5w50?
For dyno oil:
15w40 -- DIESEL oil only, If temperatures average above -5*C
10w30 -- DIESEL oil only, If temperatures average below -5*C
For synthetic.
0w40 -- DIESEL rated, year round
CJ-4,CI-4,CH-4 are the current categories of acceptable diesel oils
post #6 of 12 Old 01-31-2014, 04:46 PM Thread Starter
sorry typo.....didnt catch it.
so 0w-40...not 5w-40 syn
trob99 is offline
post #7 of 12 Old 01-31-2014, 04:48 PM
schlutzer's Avatar
Quoted: 18 Post(s)
If its a diesel rated it would be fine. Most guys run 0w
post #8 of 12 Old 01-31-2014, 04:57 PM
chevelless414's Avatar
Rotella T6
2002 Excursion 7.3
6637 filter
gauges
v&b code spring swap
hellwig rear sway bar
4" mbrp exhaust
DP- Tuning
wicked wheel
ebpv delete
chevelless414 is offline
post #9 of 12 Old 02-01-2014, 12:46 AM
Most guys? I would say some guys. I think the majority goes to 5w40.
The point is any CH-4 or newer oil will be fine, regardless of weight, with CJ-4 being the most common.
2002 F250 XLT CrewCab Short Bed 4x4 7.3L
05 Conversion - 50" LED Light Bar - MBRP 4" Exhaust - AIS Intake - PHP Tuned
USA - Thank you those who serve
A/Ox3 is offline
post #10 of 12 Old 02-01-2014, 01:36 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Er yeah. Been working with too many gas engines and keep seeing Mobil 0w.
5w 40 is generally what you'll find in diesel rated
Weight greatly affects the cold start though
