Flat towing? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-31-2014, 05:25 AM Thread Starter
surveyingdawg's Avatar
Flat towing?
Well you guys have answered my tranny question, now a different one.
Am I crazy to think I can tow a 350 with another 350?
Both are DRW.
Any opinions welcome. It will be 1000 miles of interstate.
2016 F350 DRW 4x4
surveyingdawg is offline
post #2 of 6 Old 01-31-2014, 05:51 AM
hansel's Avatar
Quoted: 99 Post(s)
When you say "flat towing" you mean with a tow strap?
That far I would rent a trailer, if it was down the street then that would be OK but a 1,000 miles, I'd get a trailer.
You have plenty of truck too tow it
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #3 of 6 Old 01-31-2014, 06:56 AM Thread Starter
Have to pull 2 trailers back though. Trying to save fuel and share driving.
2016 F350 DRW 4x4
post #4 of 6 Old 01-31-2014, 08:57 AM Thread Starter
Sorry, not with a tow strap but a tow bar.
2016 F350 DRW 4x4
post #5 of 6 Old 01-31-2014, 12:50 PM
alaskan155's Avatar
Quoted: 65 Post(s)
Most tow bars are rated at 5k lbs, never seen anything over that and with the wieght of a superduty I would definitely want a brake system on it.
also.
1. You need a manual tcase or manual trans to flat tow
or
2. You have to remove the rear driveshaft or you will destroy your automatic transmission
the heaviest I have flat towed is my bronco with my old 99 f150 and it like to push the backend around.
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #6 of 6 Old 01-31-2014, 01:58 PM Thread Starter
It is a manual. I will also remove drive shaft. I have found several tow rated for 8500 and 10000 lbs.
are there any bad towing habits the truck will have. If it's a hassle I'll just drive. But I will be making a trip a month up there to get 2 trsilers and it sure would be easier driving up with one truck and 2 drivers.
2016 F350 DRW 4x4
