Curious about stock boost ... - Ford Powerstroke Diesel Forum
post #1 of 18 Old 01-31-2014, 04:07 AM Thread Starter
ChiefRocka's Avatar
Hey Guys,
Well the first mod was to remove the AIH element, and plug it with a RiffRaff plug with 1/8 pipe port....So I would be ready for gauges later
I found this Old Autometer 'Blower' PSI guage from one of Father-n-Laws Mopar builds that was never used ....
Still in ratty box, labeled '89 !!
So I decided to run a line. (I ran it long, with excess tied away for a future use in pillars gauges) currently mounted under dash
I noticed this guage falls back (pegs) past the "0" mark, and as you slowly drive, is raises up to "0" then maxs at about 19.5/20 psi.
So considering how much the guage is past the "0", I'm assuming its not reading right ?
I'm not sure, this is why I ask ....
Stock truck with a downpipe is all.
Wondering if the guage is FuBaR ??
Or mabey i'ts because I'm used to all the gauges featured in the Fast n Furious movies that peg to max in the Civics ???
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 18 Old 01-31-2014, 04:22 AM
Macon's Avatar
Is there not an adjustment screw to allow you to set "0" with the engine at idle?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 18 Old 01-31-2014, 05:46 AM Thread Starter
ChiefRocka's Avatar
Hmmm, I dont think so,
But ill check again.
John
post #4 of 18 Old 01-31-2014, 05:50 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I think this is one of the biggest misconceptions about boost gauges. It is perfectly normal for it go below 0. Why you ask?? Well it has to do with altitude. Most good gauge maker SHOULD calibrate the gauge to 1 atm(sea level) just for consistencies sake but id guess most dont and are calibrated at whatever altitude their factory is at.
So if they set it at 0 psi at their altitude say 1000 ft above sea level and they ship it to you and you get it and open it at say 5000 ft above sea level your going to have less ambient air pressure at your altitude so the gauge reads slightly lower than 0 psi.
Some guys say its because a diesel creates a small vacuum at idle that is true for a N/A diesel, but thats incorrect for a turbo diesel. It doesnt create a vacuum it creates pressure because the turbo pushes the air into the intake but at idle its so little that it doesnt register on the needle until the boost starts to build.
So in short no the needle should read below the 0. Sorry for the long winded response but i see this misinfo every few months or so. As for an adjustment screw i doubt it ive never seen one on a gauge but ive never seen ever gauge out there.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 18 Old 01-31-2014, 06:21 AM Thread Starter
ChiefRocka's Avatar
Ok, thanks guys ....
But ....
Does anyone know what the stock psi is/should be ?
John
post #6 of 18 Old 01-31-2014, 06:29 AM
Chapter Director
Quoted: 5 Post(s)
But ....
Your right on it, 202 psi is about what you can push out of a stock truck
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 18 Old 01-31-2014, 05:12 PM
blue99stroker's Avatar
Quoted: 272 Post(s)
id say about 17 psi max stock tune with 4 inch exhaust and a better intake.
a truck with generic programmer 21-24 psi.
stock tune with riffraff billet, exhaust, intake, high flow exhaust outlet and red line unplugged i can get 26 psi
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #8 of 18 Old 01-31-2014, 05:56 PM
Chapter Director
Quoted: 5 Post(s)
I have no problem reaching 20+ in my stock tune going up a moderate hill thats before i unplugged the red tube too
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 18 Old 01-31-2014, 08:06 PM
Joel's Avatar
Quoted: 10 Post(s)
I can hit 20psi with the stock tune as well.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #10 of 18 Old 02-02-2014, 11:33 AM
7.3LDriver's Avatar
Quoted: 5 Post(s)
What is this red tube and where is it? I can use all the boost i can get.
E99 F350 eclb drw 7.3L 4X4
220,000miles
leveling kit
35" tires
Donaldson Replacement 6637 Filter
Diamond eye 4" TB
ts6 with informant6 monitor
180/30 full force diesel injectors
d66 turbo
Riff Raff HPX and FRX
valair clutch
Zoodad Mod
Cam-locker toolbox
7.3LDriver is offline
