Loud hiss in OD towing, NOT SURGE! - Ford Powerstroke Diesel Forum
post #1 of 28 Old 01-30-2014, 05:32 PM Thread Starter
Quoted: 2 Post(s)
Trying to figure out what's up with my 02 7.3. Took a trip out of state towing a 6x12 enclosed trailer with toys in it weighing maybe 4000#. Any time there was any sort of grade to climb (Florida...) or i needed to speed up a bit, the hiss would start. I have a diy tymar intake and the sound seems to come from there. The hiss starts, my scanguage says 5psi boost, hiss gets louder and boost goes up to maybe 7 trying to maintain 60-65mph. It takes a ton of throttle, 30-40% in many cases, just maintain speed. Instant fuel economy goes to single digits and the truck just feels like a dog. I couldn't imagine what it would be like towing an actual load. I can accelerate down an on ramp and hear a clean turbo whine and see modest boost, maybe 13-15, and as soon as overdrive hits, the hiss starts and power disappears. Also, for several miles of flat ground I could maintain 65 with 16% throttle, then out of nowhere I start to slow down and for a few miles it takes 22% throttle to maintain speed. Its a constant hiss, not a flutter, I've heard surge before and this is not it. Even when unloaded and going up a hill I can hear it start at as low as 4 pounds of boost. I have no soot anywhere around the up pipes, I have triple checked my boots, and am running a 60hp economy tune and a 4" exhaust. Please help!
Whitson Metalworks is offline
post #2 of 28 Old 01-30-2014, 06:25 PM
Zaairman's Avatar
Quoted: 12 Post(s)
Sounds like your EBPV is closing maybe?
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 28 Old 01-30-2014, 06:29 PM Thread Starter
Quoted: 2 Post(s)
Crap, forgot to mention its unplugged. Got tired of the jet noise in the mornings.
post #4 of 28 Old 01-31-2014, 06:14 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
sounds like a boost leak somewhere.
stock truck (stock tune) can hit about 15-17 psi of boost.
the tymar filter setup is noisy as well. could be it just sucking air.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 28 Old 01-31-2014, 06:19 PM Thread Starter
Quoted: 2 Post(s)
Thanks man, I only hear the sound in OD. Accelerating through the gears its a clean turbo whine with only some stall at shifts, which I'm sure is normal. Once it hits od its just constant under load. I have seen 15 psi accelerating sort of hard.
post #6 of 28 Old 01-31-2014, 06:32 PM
SS4Matt's Avatar
Sounds like you have a boost leak. Does it sound like air squeaking out a balloon as you pinch it?
I had to recently replace my old stock deteriorated valley silicone couplers and charge pipe couplers because the pcv oil had deteriorated my stock ones.
02 F-250 7.3 Powerstroke PMF Suspension 20" XD Hoss 325/60R20 Dura-Tracs
38R 4" MBRP TW Chip HPX Mod EBPV delete 6637 Billet Converter Shift Kit Autometer GS
SS4Matt is offline
post #7 of 28 Old 01-31-2014, 06:35 PM Thread Starter
Quoted: 2 Post(s)
Nope, its a hiss, a "deep" hiss. Imagine an air hose blowing inside a piece of tube, I know that sounds odd. I check all clamps and couplers and all are tight and supple, not dried or cracking. The noise sounds like its coming from the intake area, I just don't like how it happens and power drops and mpg tanks.
post #8 of 28 Old 02-01-2014, 12:03 AM
Maybe you have a leak on your intake somewhere? double and triple check from the intake all the way to the turbo. That would explain why their isn't any soot
99' F-350 CCLB 92,100 miles ▬ 05 headlights 4" exhaust 6637 Gauges F650 dash blue LED interior HID Headlights & offroad lights 20" LED lightbar PHP Hydra 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #9 of 28 Old 02-01-2014, 07:06 AM
Quoted: 249 Post(s)
you have to pressurize the system to accurately see any cracks/leaks.
post #10 of 28 Old 02-01-2014, 06:40 PM
'01SilverBullet's Avatar
Quoted: 4 Post(s)
To me it just sounds like the intake under load when it's in high gear. Mine makes the exact same noise in those circumstances.
2001 F250, 7.3, Automatic, 4x4, 33's, Leveled, Cobra 29 CB Radio, Dual Firestick Whips, Pioneer Head Unit, Riffraff 6637 Intake Kit, 4" turbo-back straight pipe, Dual Alternator Upper Radiator Hose, AutoMeter Boost, Pyro, Trans Temp, Delta Toolbox, Gooseneck Hitch and a heavy right footed driver...
Wishlist: 160cc single shots, GT38r, BTS, SRP 1.1
REAL TRUCKS DON'T NEED SPARKPLUGS!!
Lord, please take care of this drivin' fool...
'01SilverBullet is offline
