Towing in higher tunes? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-28-2014, 09:03 PM Thread Starter
Gaius's Avatar
Quoted: 43 Post(s)
I'm leaving in a couple days, towing about 6000 lbs. I haven't towed with this truck yet.
7.3/ZF6, Stock injectors, stock everything except intake and exhaust.
The tunes between my Econ and "Street" I don't like. I don;t use them, and won't get them again on a reburn. However, I don;t have time to get them reburned.
How likely will it be okay in the higher tunes (Street) towing up the passes? Econ does great unloaded, fell on it's face with a load of firewood. No problem with EGTs with that. So I want to use Street if I can. I can use Daily, but it has a lag and is too smoky. The tow tune is terribly low on response and power, so I can't use that.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #2 of 7 Old 01-28-2014, 10:46 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
it will drive just fine, just watch egts.
fwiw my 60hp tow tune from php rocks.
the shifting is rock solid and its almost as powerful as 80hp daily driver.
i can get 30 psi of boost on 60 tow and egts are so friggin low.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #3 of 7 Old 01-28-2014, 11:50 PM
Macon's Avatar
If your dd tune smokes a lot, and your tow tune feels like crud, I can't give you an honest guesstimation of how well it will perform with your other tunes. But, if you have gauges and can monitor your EOT, EGT, and TFT, then I think you'll be fine. Don't let any of those temps get stupid and you shouldn't have a problem. I know people that tow 14K on a 140 tune; regularly, and without issue. Drive like you're towing something, and pay attention to temps.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 7 Old 01-29-2014, 09:50 AM Thread Starter
Gaius's Avatar
Quoted: 43 Post(s)
Sounds good. The "Street" tune is similar to a 120 tune from DP I would say. I'm hoping I can stay in that tune the whole trip (1100 miles with three passes to go over).
However, it won't be too big of deal to move into DD when climbing if it runs too hot. It's just smokey taking off at lower RPMs. I can use it as my "smoke tune".
When I get back I'm going to spend the money on a Hydra and have a tune made right in between the Econ and Street, and ditch everything else. Don't need 6 tunes with a 6speed....
05 F350 Crewcab
Gaius is offline
post #5 of 7 Old 01-29-2014, 09:57 AM
Macon's Avatar
With the 6 speed you should have no problem keeping EGT's down. I missed that in your first post. I have an auto and like the choice of tunes, but with a manual I probably wouldn't as much.
High idle and whisper are nice though. I would likely leave it in a 120 position most of the time as well. I already do with my auto.
2002 F250 CCSB 4x4
Macon is offline
post #6 of 7 Old 01-29-2014, 10:50 AM
CSIPSD's Avatar
I towed in my race tune from Swamps for 60k+... Watch your EGT's and hammer down...
That was with 250/200's too...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 7 Old 01-29-2014, 05:17 PM Thread Starter
Gaius's Avatar
Quoted: 43 Post(s)
Awesome, thanks Joe.
Heading to the Hammers on the morning. Woot!
05 F350 Crewcab
Gaius is offline
