removing a 4" lift - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-28-2014, 04:54 PM Thread Starter
If it aint a CAT itsa DOG
dieseldan2005's Avatar
removing a 4" lift
Guys i am looking at buying a 2002 f350 that has a 4" lift with 35's on it. It is a very nice truck, but i pull a 5th wheel camper and gotta get her down. How much is involved in going back to stock? I need to know how much i will have to invest into it to make it work. I also want to go back to stock rims/tires. I don't think my 5er will fit because its been close with my other trucks that were stock height. Let me know what you guys think. I might buy it tomorrow if i can do the swap easily enough.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #2 of 12 Old 01-28-2014, 05:06 PM
jse51599's Avatar
Depends on what type of lift was used. You will need to know if all springs were replaced to gain the lift, or new springs in the front/blocks in the rear, etc. Was the pitman arm replaced, new track bar, etc....? Do you know how old the lift kit is? Those are some of the things you'll need to know in order to get the right parts to go back to stock. I've seen previous lift threads where guys tow with 4" lifts regularly.... does your trailer sit lower than normal?
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
post #3 of 12 Old 01-28-2014, 05:06 PM
03ranger30's Avatar
The same as putting a lift on the truck, just the opposite. Just take the lift components off (springs, trac bar, shocks, and anything else) and put the stock stuff back on.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #4 of 12 Old 01-28-2014, 05:09 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Yup without knowing all that Dan its hard to say.
Ive got a better possibly less expensive idea. Shackle flip on the trailer
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 12 Old 01-28-2014, 05:12 PM
jse51599's Avatar
If it would work out, I'd trade you parts, but mine is a late 99.....
Jim
jse51599 is offline
post #6 of 12 Old 01-28-2014, 06:03 PM Thread Starter
Yeah dave, i have thought about that, but i might be hauling things around where i need a stock height truck all the time and raising my 5th wheel wouldn't solve all my issues completely. Do you guys also know if an 04 excursion has the same suspension parts or are they slightly different? I ask because my brother has an ex and wants a lift. I know the front suspensions are both leaf sprung, but not sure if the blocks and shocks would bolt up.
Diesel Dan
post #7 of 12 Old 01-28-2014, 06:06 PM
jse51599's Avatar
Not sure.....
Jim
jse51599 is offline
post #8 of 12 Old 01-29-2014, 04:16 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Excursions have softer, lower-riding springs front and back. Rear shocks are diffrent if I recall corrrctly.
Best bet is buy new springs, as any you might trade for are likely sagged or worn out. Sell lift stuff to recoup some cash. You will likely need new u-bolts, local place here does them custom for about $70 an axle. Track bar and pitman arm should be checked. Compair what you have to a stock truck to see what's diffrent.
Trading with someone can be done but risky. Both trucks are torn apart... the time and place to have room tools and people is hard to come up with for most. If done on a week end and unknown issues arise (like broken parts/hardware) you're down and truckless till Monday when shops open.
Good luck in your quest...
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #9 of 12 Old 01-29-2014, 09:43 AM
CSIPSD's Avatar
Have you tried hooking to it, 4" is not that much, bet it would tow just fine...
I've towed everything under the sun with a 4" and 37's...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #10 of 12 Old 01-29-2014, 10:04 AM
Koda22's Avatar
Quoted: 5 Post(s)
Yea I've always heard it's harder to remove one then it is to put one on....atleast when you weren't the one that installed it, and as far as towing I would think you should be fine...I've seen more then my fair share of people towing with a 4inch lift..
Koda22 is offline
