Are these two issues linked to low fuel pressure? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-28-2014, 03:51 PM Thread Starter
Quoted: 2 Post(s)
I was starting to think I had a low fuel pressure problem due to my f250 being quite sluggish and sometimes chugging when accelerating up hill. However, a few times in the last 2-3 days, when I tried accelerating from a stop sign, the RPMs raised and then dipped way down to about 500. I let off the gas and then it would go back up to the normal RPM and accelerate fine. Today though, she died under acceleration. The engine was definitely cold, but I was taking it easy.
Now in the last few days, it has been really damn cold here in Wisconsin. Today it got down to as low as -15F and it was sitting outside while I was at work. (I do use an anti-gel as well)
Do you think there could be a low fuel pressure causing both of these (dirty in-tank filters or something of the sort) or could this all be linked to the cold? I have only owned this truck in the winter so I am unsure how much of an effect it is having on my truck.
winona78 is offline
post #2 of 6 Old 01-28-2014, 06:38 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Could be fuel...you'd have to check pressure to know for sure. How's your fuel filter? Might be cps related too
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 6 Old 01-28-2014, 06:43 PM Thread Starter
Quoted: 2 Post(s)
I replaced the fuel filter today. The bowl had very clean diesel in it. When I was pulling away from the shop after installing the filter it stalled.
Is there a way to see if the CPS had been changed at an earlier date?
winona78 is offline
post #4 of 6 Old 01-28-2014, 06:51 PM
Doesn't Even Care
Quoted: 69 Post(s)
Unless you have records, no. Put a scan tool on it, watch your icp and vitals, see if you can tell what's going on
Nick
"The Mistress"
post #5 of 6 Old 01-28-2014, 10:51 PM
Quoted: 3 Post(s)
doubt its fuel pressure. fuel pressure would be missing injectors and super high EGT's (600+ degrees at like 10mph)
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #6 of 6 Old 01-30-2014, 09:31 AM
Eco Taxi's Avatar
I'm thinking check the ICP, CPS, IPR but could be fuel pressure
Without a scan tool you cant know for sure and a fuel pressure gauge
I'm currently fighting an issue that started off like that, now it won't start but since I've replaced my ICP, CPS, and IPR and have my in tank mods done I'm chasing a fuel issue.
After I replaced my IPR my truck ran a lot better until this current issue
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
