Old 10-14-2008, 01:17 PM
Mud-Nut Mud-Nut is offline
Send a message via MSN to Mud-Nut
Help Figure Out Leveling Kit?
Hey guys.... I'm new to the forum (posted in the intro area) and just got myself a 2001 F250. The guy I bought the truck from didn't really seem to know much about the specifics of the truck (the "stock exhaust" turned out to be a Gale Banks exhaust).
Anyways.... I believe my truck has a leveling kit on it. The truck has 315's on it and it sits level.
Now I'm hoping someone can help me figure out which leveling kit was installed on my truck (if any)? Let me know what I should be looking for, or what pictures I should be taking to show you guys?
Any help would be greatly appreciated. Thanks!
Old 10-14-2008, 01:24 PM
Justinlw Justinlw is offline
Send a message via MSN to Justinlw
take a shot of the shackle and hanger on the front springs, and also the perch that the spring sits on (on the axle). You should be able to tell from there if anything has been changed.
Old 10-14-2008, 01:38 PM
as you wish.....
Old 10-14-2008, 01:42 PM
looks like a 3.5" hanger lift to me. Do you have two blocks under the rear or 1? How tall is the block?
Old 10-14-2008, 01:48 PM
Only 1 block in the rear... Measures 3.5" tall.
Old 10-14-2008, 02:06 PM
That's a Rize (I think) 3.5" lift. It comes with the front hangers, and a block that's 1.5" taller than stock for the rear to level it out. Good Find on the truck.
Old 10-14-2008, 02:11 PM
szyd szyd is offline
Should the front leaves look that way? Lika rainbow instead of a bowl.
Old 10-14-2008, 02:21 PM
almost every 4X4 SD I've seen has looked like that. Mine did before I swapped the springs.
Old 10-14-2008, 02:26 PM
So it's a 3.5" lift then? That's cool... Thanks!!
Taller block in the rear.... But what about the front? Is the front hangar different, and that's it? Or is the rear shackle different from stock too? Sorry about all the questions, I'm just trying to wrap my head around everything. I know old Ford's inside and out... But this newer stuff is fresh for me!
Old 10-14-2008, 02:28 PM
badazzstroker badazzstroker is offline
no leveling kit on that truck from what i saw in the pics
