Question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-27-2014, 01:20 PM Thread Starter
shortrac's Avatar
Question
Would a power inverter b stupid with timer on it to warm my block 45 minutes b4 I leave work since it's 10 out n I can't plug truck up during the day. I leave my truck n a parking lot for 10 hours a day n ride to work with other people. ..
startin over with a stock 2000 f250 crew cab 4x4 shortbox lariat w/288k miles
shortrac is offline
post #2 of 9 Old 01-27-2014, 01:23 PM
dannanw's Avatar
Quoted: 67 Post(s)
Garage
it would drain your batteries faster then it would warm it up...block heaters take a good bit of amperage.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 9 Old 01-27-2014, 02:44 PM Thread Starter
shortrac's Avatar
Even for 45 minutes it would kill battery's. Then how much is it pulling at my house then
shortrac is offline
post #4 of 9 Old 01-27-2014, 02:57 PM Thread Starter
shortrac's Avatar
But if I had a spare battery that was a marine battery that sat n a tool box that charged as truck runs like on a trailer that u pull that has a battery for a winch then it should work ?
shortrac is offline
post #5 of 9 Old 01-27-2014, 02:59 PM
Riseinside1892's Avatar
It's a 1000 watt heater I believe so at 110 volts it's pulling 9-9.5 amps
Jake
2002 F250 ECSB 7.3 146,xxx mi
Afe intake
Diamond Eye 4" straight exhaust
305/70R16 Fierce Attitude MT
Riseinside1892 is offline
post #6 of 9 Old 01-27-2014, 03:01 PM
That could work. I'm not too sure how long it would run without charging but you could even set a timer to it. Usually it only needs to be on about 3 hrs before starting.
Jake
Afe intake
post #7 of 9 Old 01-27-2014, 03:44 PM
Riseinside1892 is right it will need alot longer than 45 minutes to make a difference.
What is the reason behind doing this, you shouldn't have any issues starting when its that cold so I would be looking into fixing why it wont start vs ways around it. Or are you just wanting to make for easier starting, would be easier and cheaper to just run the 5w40 in the winter.
cory99 is offline
post #8 of 9 Old 01-27-2014, 03:57 PM
Quoted: 2 Post(s)
A 1000 wat block heater will draw approx. 9 amps at 120 volts. If we assume that the inverter is 100% efficient, which it is not, the inverter would draw a minimum of 90 amps at 12 volts. Your battery would have to be able to maintain an output of about 100 amps for a minimum of 3 hours without the voltage falling too far. Each inverter is a bit different, but if the voltage drops too low, the inverter will shut down.
inspectorCSS is offline
post #9 of 9 Old 01-27-2014, 05:39 PM Thread Starter
shortrac's Avatar
No issues at starting today it was 12 here n it started with no problem I jus no in theory that a warm motor to start is better than cold 1
shortrac is offline
