8 Inch Lift? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-27-2014, 05:01 AM Thread Starter
eratliff88's Avatar
8 Inch Lift?
Whats a good 8 inch lift for a good price? Also, with an 8 inch lift what mods would i have to do for it to work? (brake lines, drive shaft, etc.)
eratliff88 is offline
post #2 of 3 Old 01-27-2014, 08:14 AM
Quoted: 3 Post(s)
......What price range are you in?
Driveshaft will need to be dropped. If you have any configuration other than a CCLB, I suggest a 1-piece driveshaft
You need extended brake lines
Adjustable track bar, drop track bar bracket, drop pitman arm
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #3 of 3 Old 01-27-2014, 11:12 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
I'd look at Icon if your wanting a good ride quality.
Front DS likely will need to be made longer.
Rear best option is add a CV after the carrier bearing.
PM me if I can help.
CT Performance, Inc. is offline
