Post Fuel Bowl rebuild Question - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-27-2014, 04:56 AM Thread Starter
Quoted: 2 Post(s)
I finished rebuilding the fuel bowl and reinstalled last night. I have 2 questions about it after starting it back up.
1st: it smoked like I have never seen before. terrible bad. cleared up after a few minutes, but it rolled a lot of white smoke. I'm hoping this was just due to the air that inevitably got in the lines? No smoke at all this morning when I started it tho
2nd: How soon would a leak show up if it was leaking? I cycled it 5 or 6 times and no leak. Idled for about 10 minutes and no leak. drove it around a country block and no leak. Fair enough to say it's leak free?
Again, thanks for the help with the last couple threads on this guys
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-DieselSite Transmission Filter
--W/ Guage and Flush valve
-Factory Tech Valve Body
-Stage 2 Snow Performance Water Meth
-AFE Blade Runner Intake Manifold
-TurboMaster WasteGate Control
-DieselSite Boost Relief Valve
-AIH Delete
-Garrett High Flow Outlet
-Garrett NON-EBPV Pedestal
-Plenum Inserts
-Torque Converter Lock Up Switch
cesspool is offline
post #2 of 12 Old 01-27-2014, 10:13 AM
blue99stroker's Avatar
Quoted: 270 Post(s)
it would leak right away. so your good.
the air is probably the cause of the hard start and smoke.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 12 Old 01-27-2014, 12:36 PM Thread Starter
Quoted: 2 Post(s)
Well all the way home I smell fuel. I get home and sure enough. Fuel in the valley. The entire perimeter of the fuel bowl cap was wet and I tightened it a decent amount. Ive never as long as ive had the Excursion had a leak there. I use the napa fuel filter/lid combo with the gasket that isnt directional. Hopefully if something under the cap is leaking it wouldnt be wet all around the lid.... but nothing on my way to work. I did let it warm up for 14 minutes beforeil I left work
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-AIH Delete
-Plenum Inserts
cesspool is offline
post #4 of 12 Old 01-27-2014, 12:46 PM
Quoted: 817 Post(s)
That happens to me every dang time I change the filter. Takes a couple loosen and retighten the lid to seal the gasket. Last time I used a real thin layer of grease with my finger on the gasket to keep it from rolling.
Have you ever had feelings for a nun??? "Nacho Libre"
Corey@CNCFAB is offline
post #5 of 12 Old 01-27-2014, 12:50 PM Thread Starter
Quoted: 2 Post(s)
I hope thats all it was. I was in a bit of a rush last night at midnight to get done and to bed...
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-AIH Delete
-Plenum Inserts
cesspool is offline
post #6 of 12 Old 01-27-2014, 02:00 PM
Quoted: 270 Post(s)
i use the oem cap with racor filters and ive never had one leak
the racor filters have the beveled oring
post #7 of 12 Old 01-27-2014, 02:03 PM
Quoted: 817 Post(s)
Explains my issues. Lol. I haven't had to change filters yet, but the next two are from Bob Riley sitting in the storage cabinet.
post #8 of 12 Old 01-27-2014, 02:17 PM
CSIPSD's Avatar
Cant find my fuel bowl... Can someone help me find my fuel bowl...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 12 Old 01-27-2014, 02:34 PM
Quoted: 817 Post(s)
Go into your bedroom. Face your rear to the tall mirror, drop ur draws, then spread em. Maybe its in there. Buhahaha.
J/K Joe.
post #10 of 12 Old 01-27-2014, 06:57 PM
Quoted: 270 Post(s)
if you cant find your bowl, no soup for you!
The Following User Says Thank You to blue99stroker For This Useful Post:
Corey@CNCFAB (01-27-2014)
