  #11 (permalink)
Old 10-14-2008, 08:56 AM
blowinsmoke blowinsmoke is offline
OK, I did notice some oil built up around the base of the turbo. But i havnt noticed any abnormal oil consumption???
  #12 (permalink)
Old 10-14-2008, 08:57 AM
Dirk Dirk is offline
Diesel Innovations
Most likely, if it is the hpop lines, it will be the fitting going to each head. But it could also be ipr or hpop leaking between the reservoir and hpop.
  #13 (permalink)
Old 10-14-2008, 08:58 AM
Diesel Innovations
If it is a slow leak, you won't notice anything but oil. It's probably been leaking for awhile.
  #14 (permalink)
Old 10-14-2008, 09:17 AM
Cool, I will check it out and maybe tighten everything up a little bit.
Thanks
