New Truck - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-26-2014, 08:47 AM Thread Starter
New Truck
Hello, I am new to this site. Just yesterday I bought a 2000 F-350 4x4 with the 7.3 and 4R100 it's got 238,500 miles on it. The body and interior are in great shape. Now the guy I bought it from just used it to pull a camper and haul tools back and fourth from Texas he had owned it since 180,000 miles and did regular maintenance. Today I was doing some research on it and it seems these transmissions seem to be the weak spot. Everything on this truck works fine as far as I know and it's got a lot of power. I paid $5,500 for it and thought I got a pretty good deal does anyone agree? Is there any precautionary measures I can take to keep that transmission working? Could this truck make it to 500,000 stock with proper maintenance? Thanks!
neal_1991 is offline
post #2 of 3 Old 01-26-2014, 09:03 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
It could easily make it to half a million miles. Like you already know, Maintanance is the key.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 3 Old 01-26-2014, 10:57 AM
Quoted: 2 Post(s)
One of the best things that you can do for your transmission is to keep it cool. if you are hauling heavy loads, the stock transmission cooler is a bit weak, but there are a couple of upgrade options available. The first is to use an aftermarket cooler upgrade. There are several good coolers available. The second option is to use a cooler out of a 6.0 litre powerstroke. The cooler will bolt right in and offers considerable better cooling. The 6.0 cooler should be available at a reasonable cost from a wrecker.
inspectorCSS is offline
