Should my e99 have an AE injector? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-25-2014, 06:17 PM Thread Starter
E99F350Stroker's Avatar
I just broke open my valve covers to do injector replacement on my e99. My #8 cylinder has an AE injector. I know newer 7.3s had the AEs to resolve cackle. Did e99s have AEs from the factory?
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #2 of 15 Old 01-25-2014, 11:15 PM
schlutzer's Avatar
Quoted: 18 Post(s)
That just means that somebody had the injector swapped due the injector knock.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 15 Old 01-26-2014, 03:44 AM Thread Starter
Ok my truck was built in 11/98 so its kinda a hybrid in a few ways. Is there any chance that it actually was put there by ford at the tail end of e99 production?
Jordan
post #4 of 15 Old 01-26-2014, 03:49 AM
schlutzer's Avatar
Quoted: 18 Post(s)
No it would have been switched, it was a fairly common thing to have done to cure cackle in the older superduty trucks., especially after the grey CPS came out.
The grey CPS causes many #8 injectors to come up as a fail on the contribution test, so many Ford dealers took even more of our money by then selling 7.3 owners new #8 injectors, by which time the AE was out so thats what people got.
Or if an owner came in with a complaint of knock, after some expensive testing, the injector was replaced with an AE...
Money grab mostly.
Mid year 2000 the AE became standard IIRC
post #5 of 15 Old 01-26-2014, 04:29 AM Thread Starter
Thanks For the info!
Jordan
post #6 of 15 Old 01-26-2014, 08:39 AM
are the rest of the injectors ADs? if not then you would have a balance fault.
I believe an AF is the long lead for AB injectors
POWER-STRUCK is offline
post #7 of 15 Old 01-26-2014, 02:00 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Basicly #8 is diffrent since it gets starved the most fuel due to firing order thats why the AE or a long lead injector is there
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #8 of 15 Old 01-26-2014, 02:08 PM
e99s did not have the AE in production, but in calendar year 2000, Ford issued a TSB (00-22-1) where dealers were instructed to install an AE injector (XC3Z-9E527-AARM) and reprogram the PCM with an updated calibration to prevent the new long lead #8 injector that was just installed from flagging a false Cylinder Contribution Test diagnostic trouble code in the future, should that test ever be run.
It is possible that the original owner took it in to the dealer many years ago to have that TSB performed. See if you find a "Ford Authorized Modifications" label anywhere in the engine compartment. If that label says 00-22-1, then there is your proof.
Y2KW57 is offline
post #9 of 15 Old 01-26-2014, 02:11 PM
If so and mixed it with ABs they made a big mistake. The displacement of the two types vary drastically
Power-Struck dot com
post #10 of 15 Old 02-03-2014, 06:47 PM Thread Starter
Power-struck all my injectors are AB except for #8 which is an AE. I realize what the AE injector is there for I just wanted to know if it was original or not. Since it isn't where in the engine compartment is the ford authorized modification sticker supposed to be? I have a miss and if the PCM isn't calibrated correctly that could be the reason.
Jordan
