EBP tube nightmare.... Need help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-25-2014, 04:15 PM Thread Starter
Quoted: 2 Post(s)
I ordered a EBP tube the other day. I just took it off and under the truck the tube nut didn't Come loose. Instead the double male connection come undone from the engine? Or whatever it's attached too. I couldn't get it off once i had the tube out still. I soaked in PB blaster and when it finally come undone, the tube side of the double male was completely stripped. The threads were left in the old tube... I have no clue what this connection is called or where I can get it but I need it ASAP. Any help would've greatly appreciated.
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-DieselSite Transmission Filter
--W/ Guage and Flush valve
-Factory Tech Valve Body
-Stage 2 Snow Performance Water Meth
-AFE Blade Runner Intake Manifold
-TurboMaster WasteGate Control
-DieselSite Boost Relief Valve
-AIH Delete
-Garrett High Flow Outlet
-Garrett NON-EBPV Pedestal
-Plenum Inserts
-Torque Converter Lock Up Switch
cesspool is offline
post #2 of 5 Old 01-25-2014, 04:24 PM Thread Starter
Quoted: 2 Post(s)
Also, I dropped the sensor into a pan of fuel (I'm also rebuilding the fuel bowl). I immediately grabbed it and cleaned it with contact cleaner. What are the odds the sensor is damaged
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-AIH Delete
-Plenum Inserts
cesspool is offline
post #3 of 5 Old 01-25-2014, 05:04 PM Thread Starter
Quoted: 2 Post(s)
I believe I may have found the part. I'd appreciate if anyone else can confirm tho.
Connector 1822713C1 International Part #
Sry for spamming my own thread lol. It's supposed to be negative 15 here Monday and 38 tomorrow and I leave for vacation Friday. I may or may not be in slightly panic mode
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-AIH Delete
-Plenum Inserts
cesspool is offline
post #4 of 5 Old 01-25-2014, 05:33 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
sensor should be fine just clean it off.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 5 Old 01-25-2014, 06:06 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Will run without it... perhaps not at ideal efficiency but run fine none the less. Had to plug one on a truck at work a few months ago. Like yours the flare nut was stripped... but the fitting came out of the manifold fine. The manifold is tapped to 1/4" or 3/8" NPT threads if I recall. The fitting that the tube goes into seems to be a flare fitting to NPT adaptor and should be avalible at any good hardware store.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
