Tips for removing collector clamp to get turbo out? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-25-2014, 03:57 PM Thread Starter
So I figured I'd go ahead and do the epbv delete and couldn't really find a write up with many pictures...
Got the intake spider out fine, down pipe taken off and the two 16mm bolts holding turbo to pedestal....
I cannot get the damn clamp on the back of the turbo off that connects to y pipes. Any tips or tricks much appreciated. Got some liquid wrench on it now hoping it will help lol but that thing is damn near welded on there....
Sent from AutoGuide.com App
01 F250 Lariat CCSB, BTS, ICON 4" on Bilsteins, 35" Toyo MT on 18" Fuel Hostage, DP F6 Tuner, 6637, 5" pipe-muffler, AIH delete, EBPV Delete, Recon Smoked lights all around, 35W Retro HIDS, Custom LED interior to include dash - not a single incandescent bulb left
HEROS NEVER FALL.... THEY EARN THEIR WINGS.... RIP LCPL JASON D. HILL - IRONMAN, YOU WILL NEVER BE FORGOTTEN. SEP 18 1990 -JUNE 11 2011
Pbguy420 is offline
post #2 of 9 Old 01-25-2014, 05:39 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
you can get a big screw driver in between the compressor housing and exhaust housing, then you can pry part of the clamp off.
i ruined my last clamp, it wouldn't come loose so i got pissed and pulled the turbo off with the clamp still partially attached, but i got it loose
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 9 Old 01-25-2014, 05:53 PM
Quoted: 2 Post(s)
It's been awhile but if I recall I ad to buy a new clamp as well. It's just as fun to put back on from what I remember
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-DieselSite Transmission Filter
--W/ Guage and Flush valve
-Factory Tech Valve Body
-Stage 2 Snow Performance Water Meth
-AFE Blade Runner Intake Manifold
-TurboMaster WasteGate Control
-DieselSite Boost Relief Valve
-AIH Delete
-Garrett High Flow Outlet
-Garrett NON-EBPV Pedestal
-Plenum Inserts
-Torque Converter Lock Up Switch
cesspool is offline
post #4 of 9 Old 01-25-2014, 06:19 PM
Wyofordpower's Avatar
Quoted: 2 Post(s)
I had to basically lay on top of the drivers side of the motor compartment to really get a good angle and space to work. After I got the bolt on the clamp loosened and uncooked I just spun the clamp on the flanges to get it loose and then pulled on the side away from the bolt and it popped off. Worst part was how that bolt was oriented when I loosened it. Was a real pita to get it unbolted. My clamp was in great shape so I just reused it but if you have to use a screwdriver definitely inspect it to see if you have to get a new clamp.
Wyofordpower is offline
post #5 of 9 Old 01-28-2014, 06:20 PM Thread Starter
I love liquid wrench. Sprayed the day of the post, came back today and wiggled the turbo and off comes the clamp
Pbguy420 is offline
post #6 of 9 Old 01-28-2014, 06:53 PM
HillbillyDeluxe39's Avatar
Step 1:
Use a long punch and hit it with a BFH!!!
Step 2:
Buy new clamp.
I was surprised how hard I had to hit mine to get it loose.
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #7 of 9 Old 01-28-2014, 08:02 PM
Gaius's Avatar
Quoted: 41 Post(s)
I had just sprayed mine down and let it sit for a bit. I pryed a little. Then while I was doing something else, it sprung off.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #8 of 9 Old 01-29-2014, 06:48 AM
schlutzer's Avatar
Quoted: 18 Post(s)
I too destroyed one while removing the turbo from my parts truck, and that was with the transmission out being able to hit it from underneath.
Now before I upgrade my E99 turbo, I have bought a new clamp just in case
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #9 of 9 Old 01-29-2014, 01:23 PM
Quoted: 249 Post(s)
ya any sort of penetrating lubricant works great, but i never have time to sit and wait.
my trucks my only transportation so i need to get it fixed as fast as possible, so a new clamp was easier in the scheme of things
