Need help removing Wix fuel filter... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-25-2014, 11:50 AM Thread Starter
Quoted: 2 Post(s)
I was trying to remove the fuel filter today to make sure it was clean and replace it if needed. It currently has a Wix 33818 with the 1" bolt head style cap. Problem is... the seal was way too tight and the top is now stripped. Tried using a vice grips too and it just cracked part of the bolt part off.
Any ideas on how I can remove this fuel filter?
winona78 is offline
post #2 of 7 Old 01-25-2014, 12:14 PM
kbragg430's Avatar
If theres enough lip to get a strap wrench or your oil filter wrench on it. Then go to an oem cap and filter!
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #3 of 7 Old 01-25-2014, 12:50 PM
RedneckYankee's Avatar
Carefully drill two small holes and insert screwdrivers or bolts into the drilled holes. Take a bar or something and place between the bolts or screwdrivers and turn cap out. Had to do this to my 05 Ex. Was a little nervous doing this but it worked just take your time drilling and make sure your just drilling into cap and filter only. Good Luck
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #4 of 7 Old 01-25-2014, 12:55 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Ha that's the filter I just bought because it has a real gasket not some stupid thin o ring
I like the oil filter wrench method, failing that drilling won't be bad, that filter has plastics instead of metal end caps anyway. If its that tight I would drill a fairly big hole, at least 3/8's
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 7 Old 01-25-2014, 01:11 PM
You could try an xl set of channel locks on the lip of the lid.
01 F350 CCSB 4x4
Leveled
AIS
4" mbrp straight pipe
Va7.3L is offline
post #6 of 7 Old 01-25-2014, 02:11 PM
F350Bigfoot's Avatar
Or buy the filter with the funky holes on top and buy the right filter socket from a tool dealer. Worse comes to worse a hammer and chisel will get it to come off. Just tap in the direction to loosen it.
F350Bigfoot is offline
post #7 of 7 Old 01-25-2014, 03:01 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 400 Post(s)
Try beating a 15/16" socket on it and try again
@loxdce
LoxDiesel is online now
