  #11 (permalink)
Old 10-13-2008, 04:55 PM
DJM DJM is offline
Could also be the Spring eye bushings mine went out and it thumped all the time if you replace the bushings I would get the urathane bushings last longer then the rubber.
  #12 (permalink)
Old 10-13-2008, 05:01 PM
penderman5 penderman5 is offline
Originally Posted by builder_one View Post
I've got the same thumping sound on my '02 F250. It only happens when I hit my brakes, does this narrow down the possibilities of what the issue could be? I'd like to take care of this myself if at all possible. Where exactly are the sway bar bushings located?
This could also be one of you lines leaking or busted, I had the same thing check to see if any of your hoses or lines are leaking.
  #13 (permalink)
Old 10-13-2008, 05:48 PM
Stroked7.3 Stroked7.3 is offline
Send a message via AIM to Stroked7.3
Alright im gonna try and start running down the list tomorrow. I've pretty much ruled out wheel hubs, bearings, ball jointsd cause the truck drives straight as an arrow.
Im thinking its sway bar bushings or spring bushings.
Cant imagine it being the shocks either due to it doesnt get any worse hittting bumps or what not, its perfect smooth driving and the thumping sound stays countinuos
  #14 (permalink)
Old 10-14-2008, 03:24 AM
NCHornet NCHornet is offline
Powerstroke Techie
Just unbolt the sway bar end links and see if the noise goes away. I think it is a 5/8" socket to remove them!! Doesn't hurt to leave them off, many have just removed them with no side affects!!
NCH
