2001 F250 ABS Reset?? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-24-2014, 03:00 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Hi all,
Was installing a back up camera in the truck....I tied it into my running lights and a red/yellow wire under the dash to my ignition switch....For some reason my ABS Light is on now...No idea why but how do you reset the ABS..? Any help is much appreciated...
2005 F350 Harley Davidson Edition CCSB SOLD!!!
Icon Vehicle Dynamics 4.5" stage 4 lift, 37x13.5R20 Toyo Open Country M/T, 20x10 Fuel Throttle wheels, ARP headstuds, EGR delete, MBRP 5" powdercoated turbo back exhaust, wicked wheel, Blue spring mod, Mishimoto Radiator, oil cooler, stand tubes and dummy plugs, Sinister Diesel coolant filter, 6.4 banjo, Air Raid air filter, SCT X4 tuner with tunes from Innovative Diesel, EGT, HPOP, fuel pressure A-pillar gauge pod
Msp079 is offline
post #2 of 3 Old 01-25-2014, 06:51 AM
ABS light is solely related to the abs system, need to run an ABS code check to see why the light is on. sensor/ pump default, loss of power to turn the pump on during inital key up when the system checks the pump ?? many posibilities
hnbperformance is offline
post #3 of 3 Old 01-25-2014, 07:45 AM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Well, I was working yesturday on it and drained the battery so i had to jump start the truck and ABS turned off....The darn back up camera just won't turn on and I have a 12v power source everywhere...Idk just frustrating
Msp079 is offline
