  #21 (permalink)
Old 10-13-2008, 04:58 AM
NCHornet NCHornet is offline
Powerstroke Techie
Originally Posted by sirnunya View Post
3.08 gears are off the shelf, Yukon, Ford, etc., not custom...but I agree. CC/SB w/ no major MPG mods is definitely not going to get near 24mpg. TS chip is not aimed for highest MPG, Dave has a special MPG tune that he runs IIRC.
This may be a new offering because about three years ago there were several of of us helping Dave look for a ring and pinion set that would fit his diff. Can't recall now what the hang up was but at that time there was nothing made for a direct replacement. IIRC it was Randy's that helped him work something out. With the price of diesel maybe somebody saw a need for 3:08's in the Superduties, sure would kill towing!!
Let me also say that if you are just filling up until the pumps shut off, this is probably the source of your innacuracy! Flow rate, air temp, and many other variables can affect when it actually shuts off. We always tell folks to fill it to the brim, to the point where you can actually see the fuel in the filler neck and it doesn't go down. This takes a few minutes at the pump, but it is the ONLY correct way to figure milage. Just filling up til the pump shuts off can easily be off by a couple gallons.
I am going to back out of this thread as I have seen where they go in the past. I wish y'all the best,
NCH
  #22 (permalink)
Old 10-13-2008, 05:29 AM
GM Duraturd GM Duraturd is offline
NCH
I could see different pumps being off some, but a couple gallons? I dont see that happening but thats just me.
  #23 (permalink)
Old 10-13-2008, 06:20 AM
bockhold bockhold is offline
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
Originally Posted by AaronATX View Post
well i just got back, and double checked this time with my GPS. filled up at a station on 21 west. from there went 78.9 miles to the station right by my house where it took 3.089 gallons to fill my tank back up. that comes out to 25.54224668 miles/gallon. and on the way back i had cruise at 70 the whole time, exactly 2k rpms. not sure exactly what's going on but the drive is mostly flat the entire way, wind could be a factor but i don't know. all i know is i did the math and this is what came out
dude that is awesome that you got 25.
  #24 (permalink)
Old 10-13-2008, 06:24 AM
driximus driximus is offline
I can totally belive it, I have made 23.97 MPG on my 02 going from Dallas Georgia to New Bern NC. and i that was hand calculated the trip to Georgia netted less at 21 mpg but on the way out there i Had to smoke check a Camero. And yes i top off the tank up into the filler neck to make sure the fuel is at the same level. I have made Numerous 21 and 22 mpg tanks only the one 23.97 though.
  #25 (permalink)
Old 10-13-2008, 06:39 AM
dereku dereku is offline
Send a message via AIM to dereku
I dont see how some people can't believe that. My buddies uncle bought a 02 7.3 recently and on a trip up from south carolina his lie o meter said 21.4 he crunched the numbers and he was actually getting around 22. Its highly believable. I have a 02 on 38 with 3.73's and at 65 I get 19.5 so 25 at 60 is very believable.
  #26 (permalink)
Old 10-13-2008, 06:40 AM
but if that was a 6.0 I would call bs with out even listening to your story those things blow
  #27 (permalink)
Old 10-13-2008, 07:21 AM
badazzstroker badazzstroker is offline
[quote=NCHornet;788033]Hank,
Call BS on whatever you want but you won't offend me!! I have been around these trucks way to long. I know they are capable of and what they aren't, I also don't believe everything I read on the internet. The person I was speaking of above is named Dave Whitmer, he is a member of another forum I was very active on for years, and I have spoken to Dave on several occasions, the last when he was building the canopy for his truck.
Here is a link to the add in Diesel Power featuring his truck!
i dont care how long you have been around these trucks i have been around and worked on all diesels since i was 5 years old i am now 26 and now manage a diesel fleet of all different kinds of diesels and anyone that has been around diesels for that long know that every diesel is different.maybe your truck does not get that kind of mileage but mine for a fact get 20 all day long and my foot is not too light if you know what i mean and i am not even running custom tunes so call bs on all you want but it is very believable.i have seen the same type motor vary hugely on mpg .
  #28 (permalink)
Old 10-13-2008, 08:21 AM
Jmaccal Jmaccal is offline
On a trip from So Cal to Idaho I got on average 21.9. Yes hand calculated and all I did was Edge Juice with Attitude. I know some people don't speak well of this system but I am very happy with it. Driving around town I normally get 18 mpg.
  #29 (permalink)
Old 10-13-2008, 09:15 AM
sirnunya sirnunya is offline
I find it hard to believe that 38's on stock gears get anywhere near 19mpg, unless of course downhill both ways with a tailwind. I've got 38's on 4.30s and have gotten 16 once or twice. Other than that, 12-14mpg. Mine is a 2000 F250
  #30 (permalink)
Old 10-15-2008, 08:11 AM
acs47x acs47x is offline
I did a 1600 mile trip through washington and set the cruise on all speed limits. Trying to be light on the throttle. I tried to make it as accurate as I could without having a the top gauge. I would let the fuel light come on each time for fill up so I calculated it to be approx. 24 gallons from the fuel light. I was hitting 485-500 miles per tank, so that would be approx. 20.5 mpg. Some of this was at 5000 feet some was at 500. Im sure elevation matters. More 02 through intake for more efficiancy. If guys are at sea level then see 24 mpg a possoibilty because especially if the have stock tire size, I am running 35 toyos.
